Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 08-21-2012, 01:41 PM
Kenny1968 Kenny1968 is offline
1959 Ford F-100
My Garage
Kenny1968 is starting off with a positive reputation.
Need Advice for Stuck Lifter
thanks in advance for the help,
I recently bought a 1959 F100 with a 292. The guy told me it had a stuck lifter and would most likely need a new cam as well. The engine runs, but has the obvious knock of what sounds like a cam lobe bangin on a stuck lifter.
Pulled the valve cover, sure enough #5 cylinder exhaust rocker is not moving at all.
Dropped the oil pan, some shiny debris found in the oil.
I'm thinking the cam lobe is shot. Now what to do?
Replace cam, lifters, pushrods? Entire rebuild? Or go with a newer 302?
Anyone have any experience with this type of issue?
Thanks - KB
  #2 (permalink)
Old 08-21-2012, 01:57 PM
jacks61ford's Avatar
jacks61ford jacks61ford is offline
Garage is empty, add now
jacks61ford is starting off with a positive reputation.
price out fixing the the 292 vs a 302 swap keep in mind motor mount fabrication trans change and fabrication drive shaft
  #3 (permalink)
Old 08-21-2012, 02:50 PM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
If compression is good, and it runs good with the exception of the miss in #5, just replace cam, lifters, timing chain & gears, and any bent or damaged pushrods.
As the Y blocks have mechanical lifters, a stuck lifter usually means that it is rusted or galled in its bore. Also, if you decide to change cam and lifters, keep in mind these are mushroom lifters.
  #4 (permalink)
Old 08-21-2012, 02:54 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
KB; Welcome to the orphanage!
As for your engine an engine rebuild is the way I would go. However not knowing what your finances and plans for the truck, you may want to chance changing just the bump stick or go all in on new drive train. So my suggestion is to take our advice and use your own judgment.LOL
Did anyone mention we like pictures?
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #5 (permalink)
Old 08-21-2012, 03:25 PM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
Also run it with the valve covers off and see if it is oiling the rockers. It was a typical issue with the Y blocks. So much of an issue that the parts stores used to sell an outside oiler kit to run oil lines to the rockers through a hollow valve cover bolt. I have also built my own after the kits were no longer available.
  #6 (permalink)
Old 08-22-2012, 11:33 AM
1959 Ford F-100
My Garage
Thanks for advice
Thanks for the advice -
Think I'm gonna try to stick with the Y Block. Gonna check the rod bearings, if they're not trashed, gonna replace cam, lifters, pushrods etc.
I'll update on my progress.
Thanks again.
  #7 (permalink)
Old 08-22-2012, 07:21 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
If you are gonna go thru the trouble to check the mains, you might as well replace them and throw on a new oil pump while you are at it!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
