Fuel pump - Ford Truck Enthusiasts Forums
Fuel pump
Old 08-21-2012, 08:28 AM
halaferd's Avatar
halaferd halaferd is offline
halaferd is starting off with a positive reputation.
Fuel pump
I have a '91 f250 7.3 and had read somewhere that instead of replacing the mechanical supply pump, an electric would be better.
Agree? If so what psi & brand of elec pump is best?
Thanks guys
Old 08-21-2012, 09:37 AM
weezer4117 weezer4117 is offline
weezer4117 is starting off with a positive reputation.
This is the one I have. Little salty but works great. This pump is made to pull instead of push fuel so mounting under the hood is no problem.
Facet Integral Filter Pump - 40223 - Discount Yacht Supplies, Vetus Nautical Accessories, Scandvik Parts, Garmin Marine Electronics
Old 08-21-2012, 09:56 AM
BeerCan500 BeerCan500 is offline
BeerCan500 is starting off with a positive reputation.
Smile Mechanical Supply Pump...aka...lift pump
Thanks guys
Hello halaferd, I would have to disagree with the electric fuel pump. Why? In my feeble mind...Yes, they would probably eliminate most hard starts due to air intrusion, but they can also mask some air intrusion problems that really should be repaired. Also in my feeble mind...I think aftermarket (out-of-tank) electric fuel pumps seem to not get along with the elements depending on where you live. There are probably other cons as well. Others may eleborate on them.
As far as the mechanical fuel lift pump...they are usually less expensive and much more reliable. Remember, this is according to my feeble mind. Why do I say this? First, the ford engineers are not dummies. (debatable).
Second, I've never owned a vehicle that utilized electric fuel pumps. I have owned my 1986 F250 6.9 for 16 of its 26 year lifespan, still drive her daily, and have never had any problems nor replaced the lift pump. In all my years driving other vehicles I only had to replace one and that was on my 7 year old 1969 dodge charger rt 440ci 4 speed.
Hope all the blabbering on helps you!
BeerCan500
Old 08-21-2012, 11:11 AM
flainn's Avatar
flainn flainn is offline
flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.
I've run both on two different trucks.
I replaced the lift pump on my '86 with an electric (the one everyone says is crap, a Mr. Gasket diesel pump) and it worked well until I sold the truck. Having an electric makes priming the fuel system much easier -- just turn on the key and push on the Schrader valve atop the fuel filter, and release when you start getting fuel. No need to crank and crank and crank until your batteries or starter die.
But, a cam-driven lift pump is simpler, probably more reliable, and if it fails I've heard a good injector pump will still keep you going until you can get somewhere to buy a replacement lift pump. An electric that fails might not let fuel pass at all.
There's pros and cons for both. I'm sticking with my mechanical lift pump for now, and I've got a spare (since I replaced it thinking it was the problem, but it turned out not to be).
Old 08-21-2012, 11:19 AM
halaferd's Avatar
I'm probly sticking w the mechanical. I'm only replacing it bc the truck is 20+ yrs old and appears to have been sitting for a period in its life. Im also replacing the injectors and glow plugs so i figured since it was so cheap... Why not eliminate one more old piece of the fuel system.
Thanks guys
Old 08-21-2012, 11:48 AM
flainn's Avatar
Thanks guys
It's an easy replacement, just undo the fuel lines and two bolts. Make sure the cam is in the right position before you install the pump, though, or you can break the arm off when you start the engine ... and from what I've heard, you've got to take the engine out to remove the sump pan to get it out of there.
I was able to rotate the engine with a 15/16" socket and a breaker bar on the crank bolt, and using a hand mirror and bright light to check that the cam lobe was pointing up.
Old 08-21-2012, 01:05 PM
Repacing injectors and glow plugs
Thanks guys
Hello again halaferd, Hey man...before you replace those injectors I would take em out and have em cleaned and pop tested. If they are within specs your good to go...lots of places will do that for a minimal fee as compared to an 8 set of injectors.
As far as glow plugs go, I would recommend you purchase MotorCraft ZD1A.
I guess you already know all that tho. Good luck...
Old 08-21-2012, 02:24 PM
halaferd's Avatar
Haha no and I never could know enough anyway so any info is always good info
Old 08-21-2012, 03:09 PM
Injectors
By the way...if you decide to have your injectors cleaned and pop tested (at least that way if you have to replace them you will know for a fact they are bad) you might want to search the forums for R & R ing injectors. That way you will know it is being done correctly. There are some things that could go wrong!
BeerCan500
Old 08-21-2012, 06:14 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
Quote:
negative. ZD-1 is for 87 and older with the old style glow plug controller. 87 and newer with the solid state glow plug controller uses the ZD-9 glow plug
Old 08-21-2012, 06:17 PM
Glow Plugs
Quote:
Sorry about that...you are right...I should have noticed we are talking about a 91...my badd
Old 08-21-2012, 06:35 PM
i ain't rite
doo doo happens!!
Old 08-21-2012, 08:55 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3 '94IDITurbo7.3 is offline
'94IDITurbo7.3 is gaining momentum as a positive member of FTE.
These electric fuel pumps that users on here use DO NOT replace the intake fuel pumps. they just replace the mechanical lift pump.
These are the SAME electric fuel pumps that refer semi trucks use and those run 24/7, 365.
the mechanical lift pumps WILL pump diesel INTO the crankcase if they fail. not sure that anybody would want that.
Electric fuel pumps can keep up with IP demands and users report increase in performance. a better, more consistent fuel supply will make the IP and injectors last longer.
looking back on it now, i wish i would have done e-fuel when i replaced my leaking mech lift pump.
Old 08-21-2012, 09:25 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
some would call me an extremist here, but i chose to have the mechanical pump PLUS an electric that ONLY runs when the glow plugs are lit or i hold the pushbutton for it. this allows me to prime the system effortlessly when air intrusion occors, while maintaining the simplicity and durability of the mechanical pump, especially since i replaced it only a year ago. i'm happy with it.
also, many who run alternative fuels experience short life from e-pumps, but no problem from the mechanical units.
Old 08-21-2012, 09:28 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Thanks guys
don't do it!
a few folks have done this exact same thing,only to find out that the replacements made in China today fail shortly after replacing their old original functioning lift pumps.
if it ain't broke don't fix it,but if you do,upgrade to the duralift e-pump.
(yes it's true,i am very e-fuel biased.but no one want's to see ya broken down due to crap replacement parts sold today.)
personally if i were a mechanical lift pump fan,i would buy used from the salvage yard before i would buy new.the originals were known (as you know) to last many,many years.
2003 f-250 v10 fuel pump??? MDSLIGHT 1999 to 2016 Super Duty 0 11-01-2015 11:08 AM
Rear fuel pump problems Beau109 1987 - 1996 F150 & Larger F-Series Trucks 4 10-26-2015 08:53 AM
Fuel Pump? creedua 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 09-20-2015 07:06 AM
fuel pumps topscrt Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 1 03-03-2014 11:37 PM
Counterclockwise 390 water pump arcticatdan FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 01-31-2014 11:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
