ok i only have 2 hands that can fit back there, its a PITA to line the downpipe up and put the clamp on it and tighten it while keeping it all straight. is there a trick to doing this?
07 f350
I did mine in the driveway on jack stands & tied string around the downpipe at the flange, pulled it up close then tied it off. That was my third hand & from there it was a snap.
Good luck!
After lots of cursing, I did the same thing and it literally took me 5min to finish.
Just did mine and the way I solved it was to get another pair of hands.... Had my brother hold it from bottom while I managed to manipulate it into place and get the clamp on and tightened
My '06 has a tab ( sorta like a flat hook) on the pipe that hooks on the lip of the turbo. The bolt on the marmon clamp straddles it. Goes together no sweat. I put the back turbo bolt in before hooking up the pipe. Little bit of xtra room helps some.
