2010 sport trac adrenalin parts
Welcome to the forum!
What kinds of aftermarket parts are you looking for? Appearance parts, engine parts, interior parts, suspension parts, exhaust upgrades?
You'll probably run in to the same issue several niche vehicle owner's face - low volume = low profit margin for aftermarket manufacturers. It's a difficult business case for an aftermarket manufacturer to design, develop, and market a product that at best will only appeal to a few hundred folks. To turn a profit, the manufacturer would then need to charge a huge amount for such parts, which further limits their market base, etc.
-Rod
-Rod
If you've found sites that offer cat back systems for the Sport Trac, and in particular the Sport Trac V8, you might check with the system manufacturer to see if there are any differences between the system for the V8 and the Adrenalin. I would suspect the exhaust is the same except for maybe the tips.
-Rod
-Rod
So far the only thing I can find is cat back for the xlt that has side exit exhaust, which will need to be modified to a rear exit. The price on that is around 500$, not including shipping to Canada.
It looks like I will have to visit a local midas to see how much it should be when I supply the muffler and have them cut it in.
Im also wondering if I should replace the resonater with after market since it's all rusted, or just remove it all together.
if your in ontario mississauga go to zoro muffler Zoro Muffler then get cold air intake by k&n and throttle body spacer by airaid thats what i did to my adrenalin, the resonater i took mine off sounds better than my buddys adreanalin.
