1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
backup sensor override button; reassign its duty?
Old 08-20-2012, 11:31 AM
bbender85's Avatar
bbender85
bbender85 is offline
so the backup sensors in the '04 i recently bought don't work, and it sounds like its not uncommon. anyways i have a backup camera waiting for me to install it and hook into my DVD headunit, so i don't need the sensors anyways.
my question; has anyone ever used the button on the dash to operate something other than the sensors? or could it even be done (is it the right kind of switch)? i am thinking about trying to convert it to activate the high idle mod.
Old 08-20-2012, 02:48 PM
bpounds's Avatar
bpounds
bpounds is offline
Why not fix the sensors? Even if you have a BU camera, those sensors are good. I love having them. I don't think they fail all that frequently, although we get a fair number of questions about them. Biggest problem is finding which sensor of the four has failed.
As far as your question, that switch is a momentary contact, so I don't see how you could use it for high idle. But you could pull the switch and make a new bezel with a maintained contact switch of your choice mounted there.
Old 08-20-2012, 03:40 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Subscribing
Be intereting to see what you could do with a momentary contact switch
hhowell1990
12-14-2012 08:24 PM
crawdad
08-08-2009 12:24 PM
Ranger1F150
05-30-2008 07:19 PM
strokersace
03-06-2008 09:59 PM
Quick Reply: backup sensor override button; reassign its duty?
