9" question
Old 08-20-2012, 01:07 PM
kevin316's Avatar
kevin316
kevin316 is offline
9" question
The rib running the lenght of the axle tube, is it a weld or something else to do with the way they were shaped? I was thiinking of grinding them smooth but I don't want to do that just to find out that it will weeken the housing.
On another note. You can sure tell that back in 79 they didn't have robots doing the welding. I ground down some of the globs of weld and found very poor welding. There were holes in the welds from someone welding over flux.
Old 08-20-2012, 02:13 PM
VocaTexas's Avatar
VocaTexas
VocaTexas is offline
I wouldn't grind on the axle tubes. Removing any material will result in some loss of strength. Without looking to make absolutely sure, I'm almost positive what you are talking about IS a weld that joins two halves of the tube.
It isn't all that uncommon for the axle to leak gear oil because of poor welds, even in later model axles. Pinholes in welds used to be fairly common.
Ikestang
07-20-2018 04:34 PM
chris989
13
08-26-2013 03:21 PM
skirk55
Delaware Chapter
03-15-2008 04:18 PM
twisted289
02-12-2007 04:47 AM
broncoman604
01-10-2005 10:34 AM
Quick Reply: 9" question
