Versions of the 9.75 Axle - Ford Truck Enthusiasts Forums
Old 08-20-2012, 07:22 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
I had a main rear outside axle bearing catostrophically fail on my while towing my race trailer to the races this weekend.
Luckily i noticed it before it got to bad.
Upon disasembly i noticed that the bearings have smaller diameter rollers than the bearings of my fathers 9.75 rear axle that i did a few months prior.
After going tot he parts store i confirmed that his 9.75 axle had heavier bearings and shafts in his 9.75 axle.
I got my axle from a junk yard a few years ago and swapped it in place of my 8.8. I didnt know there was a difference i the years so i didnt really care what year of 9.75 it was.
Turns out that the 97 9.75 axles are a little lighter duty than there counter part 98-03's. Smaller beairngs and axle shafts.
Can anybody confirm this?
Old 08-20-2012, 01:29 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
RockAuto shows every F-150 9.75" axle using the same bearing from 1997-2012.
3.0370" OD, 1.7080" ID
EDIT: It appears that certain early 9.75" axles used 34 spline 8.8" axle shafts and tubes and bearings for whatever reason. Odd.
Old 08-20-2012, 06:59 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is online now
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
there was a post on here about 6 months ago where someone ran into the "small" bearing on a 97 model.
Old 08-21-2012, 08:12 AM
Ya thats my luck. I pick up a used 9.75 to replace my busted 8.8 and i get the first year of it that is light duty. Oh well.
000 F150 with a 9.75" rear axle....problem Toplait 1997 - 2003 F150 1 10-02-2014 12:57 PM
THIS IS AN ODD CASE!! 8.8 RING GEAR BUT TAGS SAY 9.75? Welder Guy 1997 - 2003 F150 1 05-29-2012 09:23 PM
2004 fx4, axle questions? jagarcia89 2004 - 2008 F150 7 03-29-2012 09:22 PM
2007 F150 9.75 why not 8.8? 74redone 2004 - 2008 F150 13 08-19-2011 01:28 PM
8.8 to 9.75 rear end swap thecardoc Expedition & Navigator 1 02-04-2010 11:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
