Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-19-2012, 07:17 PM
Krispy Kritter's Avatar
Krispy Kritter Krispy Kritter is offline
Garage is empty, add now
Krispy Kritter is starting off with a positive reputation.
!960 Will not idle
Just bought 1960 F100 223, Holley 1904 1BBL. Timing OK.Dwell OK Opened carb and can blow compressed air through idle fuel passages. Have replaces plugs, points, condenser,& coil. Compressipon is (dry/wet)
130/140 125/140 110/115 90/95 125/130 105/115
Truck will not idle below ~1000 rpm.
Is the above compression results bad enough to cause this poor idle?
Weird fact: With the choke in "Off" position the idle speed screw with the spring on will not touch the cam that it is supposed to ride on. I had to remove the spring so i couild open it up enough to make it "idle?"
  #2 (permalink)
Old 08-19-2012, 07:48 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Well congrats on the new truck and welcome to FTE!
Sounds like you are zeroing in on the idle trouble with the carb. They are fairly simple but they do have to be put together correctly. You may have some trouble in that dept. It's tough to tell just by typing and not seeing!?!
Enjoy that ruck!
  #3 (permalink)
Old 08-19-2012, 08:46 PM
thundersnow70's Avatar
thundersnow70 thundersnow70 is offline
1960 Ford F-250
My Garage
thundersnow70 is starting off with a positive reputation.
i am a little confused. you said with the choke "off" and then you went on to say you had to take the spring off so you could open it enough for it to idle? the blade on the top is the choke. there is a blade on the bottom that is for the throttle. i would make sure the upper is open and the lower is closed all the way. if the throttle is closed all the way you should only be pulling gas through the idle circuit. but what do i know
__________________
52 F2 & F3 Merryman Herringbone
60 F250 4x4
63 F250 4x4 Flareside
Mark
I might be in a cage at the zoo, but I'm still king of the jungle!
  #4 (permalink)
Old 08-19-2012, 11:22 PM
jacks61ford's Avatar
jacks61ford jacks61ford is offline
jacks61ford is starting off with a positive reputation.
sounds like a vacuum leak to me
  #5 (permalink)
Old 08-20-2012, 08:50 AM
Thanks for all the info and support.
I tried to find vacuum leaks by spraying starting fluid on the lines but could not find any.
I said choke off, I meant open. The position of the choke controls the angle of the cam that the idle speed screw rides on to give a fast idle when the choke is closed or partially closed.
Is the throttle plate completely closed at idle? If so where does the air get in, through a passage in the carb?
Thanks again.
  #6 (permalink)
Old 08-22-2012, 12:09 PM
1959_f100's Avatar
1959_f100 1959_f100 is offline
1959_f100 is starting off with a positive reputation.
no throttle plate should not be completely closed
  #7 (permalink)
Old 08-22-2012, 12:45 PM
Thanks 1959. i am presently looking for a carb kit and a throttle body as the shaft is quite loose. Have found some but not for the correct list #.
  #8 (permalink)
Old 08-22-2012, 01:45 PM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
Usually the throttle butterflys need to be open a little when curb idle is adjusted properly, sometimes not much at all. The idle circuit should also have an idle air passage since the idle mixture screw is just that, an adjustment of the fuel/air mixture on the idle circuit
  #9 (permalink)
Old 08-22-2012, 02:18 PM
Thanks Willowbilly. I think that is part of my trouble also, the tapered part of the idle misture screw is really mashed up. Must have been tuned by a gorilla. My supplier is having problems finding my kit, hopefully will get it soon.
  #10 (permalink)
Old 08-22-2012, 07:14 PM
spurredon's Avatar
Have you looked at this thread yet?
http://www.ford-trucks.com/forums/11...-need-one.html
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
