Need Advice for Stuck Lifter
Old 08-21-2012, 01:41 PM
Kenny1968's Avatar
Kenny1968
Kenny1968 is offline
thanks in advance for the help,
I recently bought a 1959 F100 with a 292. The guy told me it had a stuck lifter and would most likely need a new cam as well. The engine runs, but has the obvious knock of what sounds like a cam lobe bangin on a stuck lifter.
Pulled the valve cover, sure enough #5 cylinder exhaust rocker is not moving at all.
Dropped the oil pan, some shiny debris found in the oil.
I'm thinking the cam lobe is shot. Now what to do?
Replace cam, lifters, pushrods? Entire rebuild? Or go with a newer 302?
Anyone have any experience with this type of issue?
Thanks - KB
Old 08-21-2012, 01:57 PM
jacks61ford's Avatar
jacks61ford
jacks61ford is offline
price out fixing the the 292 vs a 302 swap keep in mind motor mount fabrication trans change and fabrication drive shaft
Old 08-21-2012, 02:50 PM
3414's Avatar
3414
3414 is offline
If compression is good, and it runs good with the exception of the miss in #5, just replace cam, lifters, timing chain & gears, and any bent or damaged pushrods.
As the Y blocks have mechanical lifters, a stuck lifter usually means that it is rusted or galled in its bore. Also, if you decide to change cam and lifters, keep in mind these are mushroom lifters.
Old 08-21-2012, 02:54 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
KB; Welcome to the orphanage!
As for your engine an engine rebuild is the way I would go. However not knowing what your finances and plans for the truck, you may want to chance changing just the bump stick or go all in on new drive train. So my suggestion is to take our advice and use your own judgment.LOL
Did anyone mention we like pictures?
Old 08-21-2012, 03:25 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
Also run it with the valve covers off and see if it is oiling the rockers. It was a typical issue with the Y blocks. So much of an issue that the parts stores used to sell an outside oiler kit to run oil lines to the rockers through a hollow valve cover bolt. I have also built my own after the kits were no longer available.
Old 08-22-2012, 11:33 AM
Kenny1968's Avatar
Kenny1968
Thanks for advice
Thanks for the advice -
Think I'm gonna try to stick with the Y Block. Gonna check the rod bearings, if they're not trashed, gonna replace cam, lifters, pushrods etc.
I'll update on my progress.
Thanks again.
Old 08-22-2012, 07:21 PM
spurredon's Avatar
spurredon
spurredon is offline
If you are gonna go thru the trouble to check the mains, you might as well replace them and throw on a new oil pump while you are at it!
Wallingnuma
31
11-19-2012 05:51 AM
bad96
04-08-2009 03:09 AM
65'f1004x4conver
57
12-07-2006 03:05 PM
re_fill
1978 - 1996 Big Bronco
02-26-2006 06:41 PM
KJKozak2
04-21-2003 08:22 AM
Quick Reply: Need Advice for Stuck Lifter
