F350 tires - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F350 tires
Old 08-19-2012, 12:38 AM
narfzort narfzort is offline
narfzort is starting off with a positive reputation.
F350 tires
Hello,
I just purchased a 2007 F350 6.0L diesel and it needs new tires. It has 325-65-18 cooper tires now. Not sure if the wheels are stock, or their width. Has a 4" lift kit. Wheel wells have been removed. No tire rubbing issues. The tire dealer suggested going with 17x9" wheels because there are many more tires available in that size. I'd like to get a larger tire, in the 325 ballpark. Any feedback would be appreciated. I have no experience dealing with wheel offsets, so that was a concern.
Old 08-19-2012, 01:03 AM
kd0axs's Avatar
kd0axs kd0axs is offline
kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.
That tire dealer is full of it. There's no reason to go to a smaller wheel, there are plenty of sizes available for 18" wheels and most have a higher load rating in 18". 18" is a stock wheel size for these trucks, but to know if they are actually stock wheels we would need to see a picture. 325/65/18 is not a stock tire size, the stock size would be 275/70/18. 325/65/18 is roughly the same as a 35x12.50, I don't know that you could go much bigger with a 4" lift. You might be able to squeeze a 37x12.50 on there, not sure though.
If you are getting different wheels, I would actually suggest the opposite of what the tire dealer told you. Rather than go to a smaller 17" wheel, you will want to go to a bigger 20" wheel. Once you start getting over 35" tires, the 17" and 18" tires don't have Load Range E ratings, where 20" do. If you are going to be using the truck for hauling/towing, you need to have Load range E tires.
Old 08-19-2012, 07:36 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
stay 18" or maybe 20" Go to a different place.
Old 08-19-2012, 09:09 AM
Quad Racer's Avatar
Quad Racer Quad Racer is offline
Quad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to all
There are plenty of tire choices for an 18". Go to a different dealer, that doesnt want to sell what he needs to get rid of. I hate when people lie just to get rid of a crappy inventory choice.
If the stock wheels are still on there, I would definately get wider ones specially if you want to go even bigger. Sure, the bigger tires fit and alot of guys run 35's on the stockers, but the tires will wear aweful and ride even worse. I bought a combo set from an online drop shipper in my area. The problem with that is not being able to lay eyes/hands on them before the purchase. I asked guys I saw driving around plenty and advice on here before I made my choice. There are a few great threads explaining rim offset and what fits with what lift with pictures.
Old 08-19-2012, 04:26 PM
Thanks for the help. I'll keep going along the 18" path. I'll post a photo of the wheels shortly.
-Mike
Tires and wheel combo dieselsmoker 6.7L Power Stroke Diesel 0 10-27-2015 12:01 AM
2006 F350 wheel-well clearance vs 2015 F350 wheel-well clearance Milwaukee,WI 1999 to 2016 Super Duty 0 06-04-2015 11:59 AM
KMC D Back Hot Wheels jimalbert 1999 to 2016 Super Duty 4 09-08-2014 08:10 AM
18's on mpls CL superdave02f552 Excursion - King of SUVs 3 08-02-2014 09:41 PM
325-60-20 jmann1283 6.7L Power Stroke Diesel 10 01-28-2014 10:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
