Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-18-2012, 09:24 PM
rayofsi rayofsi is offline
Garage is empty, add now
rayofsi is starting off with a positive reputation.
Installed my Kenwood DNX7190 with iDatalink Maestro
Installed my kenwood today, with the idatalink maestro product that i thought would become a phantom product.
Item was beyond easy to install in my ford expedition 2011, used butt connectors, should have went with solder, but i couldnt find my heatshrink.
The module works perfectly with sync.
I tried to get my oem sat antenna to work with my kenwood using the ford splitter, but i couldnt get a signal. Kenwood supplied antenna installed behind the radio, perfect gps reception.
Love this gps! menus are a bit slow, but thats to be expected in these units.
Trying to locate my reverse camera wires, to hook up to the kenwood, then it would be perfect.
  #2 (permalink)
Old 08-18-2012, 10:19 PM
mtondreo mtondreo is offline
mtondreo is starting off with a positive reputation.
Tagging you to hear some impressions. I realized my wife's lease is longer than I expected so I will be in the Expy longer and trying to decide if I should put one of these (or similar) kenwood in. I still have my DDx 514 sitting here but would like a newer one. I had no idea that they could interface with sync until I looked on their site yesterday. Also, do you mind if I ask what you paid and from where and you are still able to bypass the video lock by grounding it. Thanks in advance, Mike.
__________________
2011 Expedition XLT 202package-superchips cortex
2006 Expedition EB 4x4 (you served us well)
previous 2003 F150 Supercrew (love the Expy, but still missed, if only you were 4x4)
1987 Ranger 4x4 (RIP)
  #3 (permalink)
Old 08-18-2012, 10:55 PM
Quote:
it is officially out as of monday, these things sell for msrp for the most part, which is pretty cheap compared to the other sync interfaces available.
Good thing about these is that it uses the sync mic, no need to install the kenwood one, and the t-harness provides every wire you need, except the steering wheel control wire, which is easily gotten to by removing the console upper finish panel, which only requires the removal of 1 screw, and not the entire console.
  #4 (permalink)
Old 08-18-2012, 11:42 PM
Click the image to open in full size.
  #5 (permalink)
Old 08-22-2012, 01:05 PM
12V Guy 12V Guy is offline
SPONSOR
12V Guy is starting off with a positive reputation.
MSRP:
Maestro RR: $169.99 (ADS-MRR)
T-Harness $34.99 (ADS-HRN(SR)-FOR01)
Kenwood SXi to ADS adaptor $19.99 (ADS-HRN(SX)-ALL01)
Website: www.idatalink.com/maestro
Look up your car from main page to see what products apply and what features are retained. You can also select your steering wheel and radio to get more specific results.
Thanks for your interest in Maestro.
12V Guy
  #6 (permalink)
Old 08-22-2012, 01:06 PM
SPONSOR
And yes, you can still bypass video lock on a Kenwood by grounding the parking brake input full time. Just ground it and don't connect it to the T-harness.
12V Guy
  #7 (permalink)
Old 08-22-2012, 05:47 PM
eddiemoney eddiemoney is offline
eddiemoney is starting off with a positive reputation.
Does the USB and line in found in the armrest still work?
  #8 (permalink)
Old 08-23-2012, 12:36 PM
Quote:
those still work, and are accessible with the kenwood.
  #9 (permalink)
Old 09-05-2012, 11:17 AM
Can you give me a little more detail on how you said it was a "Very" easy install. I am very interested in this, but a little concerned about how involved the install is. Do I have to cut wires? Splice wires? Or is is simply butting bare wires to bare wires? Thanks in advance...Ed
  #10 (permalink)
Old 09-05-2012, 12:25 PM
i got the harness they sell for ford as well.
i took butt connectors and matched the colors on the harness up with the kenwood harness, and crimped them, everything but 1 wire is in this harness.
the steering wheel control wire is in the area next to the shifter, requires removing 1 screw and the upper console trim, took a minute or 2. i cut the wire that went from steering wheel to the sync module, and connected that wire so that steering wheel goes into the new harness.
99% of the work was done indoors, since it was all in the harnesses, (idatalink harness, and kenwood harness)
after that, it is pretty much plug it back in. wished i remembered to take pictures, but it was easier then i expected it to be. if you have factory installed reverse view camera, that takes a bit more work to tap into.
  #11 (permalink)
Old 12-16-2012, 02:10 PM
Fboykin Fboykin is offline
Fboykin is starting off with a positive reputation.
Hi, I've posted some questions under your member information. Please check and contact me. Wanted to hear more about your install, how well the unit is doing, and if you got rear camera hooked up. I have a 2012 and am interested in doing just what you did.
Thanks!
  #12 (permalink)
Old 01-18-2013, 02:34 PM
Hi, I'm posting again to see if I can get a response on how well your Kenwood is working. Also had some questions on how you did your install. I think too that I need to post a few more times before I get full forum rights - right now it looks like I'm still locked out of being able to send you a private message.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
