Old skool engine reconditioners ? - Ford Truck Enthusiasts Forums
Old 08-18-2012, 02:11 PM
jazzydog jazzydog is offline
jazzydog is starting off with a positive reputation.
While I had the generator off i also removed the fan and cleaned up the area on the engine which was caked in crud,,, I discovered this tag rivetted to the block, does anyone recognise the company? are they still going?
Old 08-18-2012, 03:35 PM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
Looks like the name could be "Barnsey & Whitier" of "Greeley, Colo". Not much chance that they are still in business, there were many "authorized" rebuilders back in the day. I think that you would almost have to be a local of Greeley, Colorado to have any chance at all of knowing the history os this particular company.
Old 08-18-2012, 04:38 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
On a farm truck from Greeley, that isn't likely entirely "mud"... lots of feedlots around there! Taste it and see!
To the left side of the tag, there should be stamped letters telling you what oversize the pistons are, and what undersize the mains and rods are. They will most likely be letters, corresponding to the suffix on the basic part number. For instance, "A" is Std, "C" is +.020" on pistons. If we knew what year and which engine it would help, I'm assuming since the tag says R and 8BA that it's a flat V8.
Old 08-18-2012, 06:10 PM
Thanks charlie, yeah, the truck came from NW Kansas bordering Colorado so that ties in, Albuq, yes its a 1951 truck, V8. I have refitted the fan now, i never saw any other stamps, on the block near the tag, but i guess it would be useful to know the sizes in case i need to have work done on the engine
Old 08-18-2012, 07:46 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Quote:
Don't trust a rebuild tag to order parts as work could have been done one or more times since that rebuild tag was installed.
Every town of any size had at least one engine rebuild shop that would rebuild engines and install such tags. My guess there were thousands. The prize would be "Authorized Ford Rebuilt"
Old 08-18-2012, 07:50 PM
ALBUQ F-1's Avatar
postin' fool
Quote:
Originally Posted by raytasch View Post
.... The prize would be "Authorized Ford Rebuilt"
His tag says that (well, "Ford Authorized Reconditioner")! I'm surprised Greeley had an authorized rebuilder because Denver is less than an hour away. Could be because of all the farm equipment around Greeley. Then again, it could just be hype.
need help; 6v voltage regulator wiring jazzydog 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 08-19-2012 09:01 AM
'51 F3 about to hit the road, any tips on recommisioning? jazzydog 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 08-04-2012 09:31 AM
V8 Flattie bellhousing pre 48 & 49 on jazzydog 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 01-02-2012 04:41 PM
Anyone got any ideas what this hole was for?? jazzydog 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 06-21-2011 06:21 PM
'51 F3 - which wheels fit? jazzydog 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 05-29-2011 06:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
