Exhaust
Too open ended of a question.. much to choose from like tubing size, mufflers, and where it terminates.
Here's my rig: 390FE, Hedmans, 2.5-inch mandrel bent tubing through Moroso Spiral Flows, and terminating at a NASCAR-style boom tube exhaust tip in front of the right rear tire.
<embed width="440" height="420" type="application/x-shockwave-flash" src="http://v5.tinypic.com/player.swf?file=34gpukh&s=5">
True. These rigs aren't high revvers. In principle, 3-inch tubing from the collectors into a dual inlet muffler with 2.5-inch single outlet is acceptable. Same with 2.5-inch tubes into dual inlet muffler with a single 2.25-inch outlet.
But hey, dual exhaust is much cooler and gives the rig street cred...
Is your truck 2wd or 4wd? If they are chassis exit (inside the frame) you have to contend with the trans crossmember first, your collectors are probably 4" to 6" or less from it right?
Dvrs side come over by the pass side pipe, and both down the r/h side of the xfer case (above the crossmember), then split one over to the other side.
Turn out in front of the rear tire, saves bends and pipe which ='s money saved. I hear Flow Master 40's are nice, but they are a little $.
Run some true duel pipe above the crossmember then put the H pipe aft of that to equal the sound out (so I hear) and keep going towards the back, you want it straight out the back or turned out behind the rear tires?
If you have the side fuel tank both pipes will have to go down the passenger side, also have it start to turn out once above the axle so it will not be hanging under your gas tank.
That can clearance issues and makes for a PITA to drop the tank.....
Purple Hornies ought to sound nice?
