06 f350 diesel - Ford Truck Enthusiasts Forums
06 f350 diesel
Old 08-18-2012, 09:53 AM
conandan conandan is offline
conandan is starting off with a positive reputation.
06 f350 diesel
Just bought this truck. I am a little nervous about the 6.0 L. I know ford has had a lot of problems with them, and was wondering if anyone could give me a better idea of what I should expect. It has had new injectors and oil pump it has 150,000 miles.
Old 08-22-2012, 11:04 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Power Stroke Diesel forum.
Old 08-22-2012, 12:58 PM
lupuseven's Avatar
lupuseven lupuseven is offline
lupuseven has a great reputation on FTE.lupuseven has a great reputation on FTE.lupuseven has a great reputation on FTE.lupuseven has a great reputation on FTE.
Welcome to FTE, great place and even better people here.
I am new to 6.0 as well, all in all to keep it in good order its maintenance. New injectors and oil pump are a good start to not having big issues. From all the research I have done on these three things to do first. One is the blue spring upgrade, check health of FCIM, and clan egr. These three things seem to be main culprits of many probs. All are in tech folder and easy to do. while your there read the new owners thread. Lots of good info there I pretty much read everything there and printed out the no start trouble shooting to keep with me in truck.
Gratz on truck and good luck!
Old 08-22-2012, 02:45 PM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Welcome to FTE
You should look into a coolant filter. Change the coolant if I recall
each 36K miles with a good flush. Get a Scanguage II and add the Xgauge
codes for the things that you need to watch. Run with stock Ford oil and
fuel filters and make sure that you have a Ford oil filter cap. The aftermarket ones
will cause problems. Change oil at least every 5,000 miles and fuel 10K to 15 K.
I use Rotella T6 synthetic oil. Drive it like you stole it is the same thing
I was told when I first got mine this helps keep the turbo from
sticking and popping the heads with a high boost.
I also agree that you should put the blue spring upgrade in it. That keeps
the injectors from starving for fuel and kicking the bucket on you.
Low fuel pressure really does damage then. Also water and air are not good.
Each oil change It is a good idea to open the water valve on the pump/filter
that is on the frame rail to drain off any water that it has in it.
Check the batteries. Bad or low will cause problems with the FICM
(Fuel Injection Control Module)
Ask questions about things you don't understand and read other things.
One very good place to start is the tech folder at the top of the main page.
http://www.ford-trucks.com/forums/30...ch-folder.html
We have a lot of very well informed people that are willing to share what they know.
I have a 2006 F350 Crew Cab Long Bed That is my first diesel. I purchased
it this last March and have put about 15K miles on it so far.
Now that I have blabbered on Just treat it right and
Enjoy your truck
Sean
Old 08-22-2012, 08:07 PM
Thanks for the info. It has a bully dog on it but ive never heard of the blue spring upgrade ill have to look into that one. I plan of doing an egr bypass here soon. And again thanks for the info.
Old 08-23-2012, 03:59 AM
Yahiko's Avatar
You may want to do some research into the bully dog.
There is some word that it likes transmissions for lunch.
I don't know this for sure but there has been some discussions
about this.
Sean
Old 08-23-2012, 06:25 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
+1, get rid of the bullydog
You need gauges. ScangaugeII is the best value. Add to that a fuel pressure gauge and maybe later on add an EGT gauge.
Smog test BS lowbed dud 1999 - 2003 7.3L Power Stroke Diesel 3 06-26-2013 10:22 PM
History Reports Sunline Fan Excursion - King of SUVs 2 03-04-2012 08:06 PM
Bent valve maxxoffroad 1997-2006 Expedition & Navigator 0 12-09-2011 10:46 PM
Transmission problems? HIROLLN 1999 to 2016 Super Duty 50 03-05-2010 08:21 AM
F-650/F-750 PROBLEMS SWT 1999 to 2016 Super Duty 3 09-13-2001 03:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
