16" or 16.5" 5 lug rims - Ford Truck Enthusiasts Forums
Old 08-07-2002, 05:49 PM
impact impact is offline
impact is starting off with a positive reputation.
Does anyone know where I can find 16' or 16.5" 5 lug rims to fit a ford truck F150? They need to be the 5 on 4.5 bolt pattern.Does anyone even make these rims??
Old 08-07-2002, 06:28 PM
restorit's Avatar
restorit restorit is offline
restorit is starting off with a positive reputation.
[updated:LAST EDITED ON 07-Aug-02 AT 07:30 PM (EST)]They're made, but they're not very popular. I used to have a set on an F150. The last time I checked, Summit Racing carried them (I believe in American Racing or Eagle). I only happened to look at the white spoked "wagon" wheels, which is what I had, but they may also be available in other styles..... (I'm speaking of 16 X 7's..... I'm unsure of the case with 16.5's or wider widths).
Old 08-08-2002, 05:43 AM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
In any case stay away from the 16.5 rims, as they are hard to find tires for.
Old 08-08-2002, 06:07 AM
rabidranger's Avatar
rabidranger rabidranger is offline
rabidranger is starting off with a positive reputation.
There are in fact plenty of tires available for the 16.5" rim. I would go with the 16" though due to the nature of the 16.5" rim being more susceptable to losing the tire bead when aired down too low. Like 10 psi or lower... speaking from experience here...
Old 08-08-2002, 09:44 AM
Ford Truck Racer Ford Truck Racer is offline
Ford Truck Racer is starting off with a positive reputation.
Try checking a junkyard for latter model trucks. the 97 later I use 16's and I believe they are the same bolt pattern. You just have to measure it.
Old 08-08-2002, 11:11 AM
brown 4x4 brown 4x4 is offline
brown 4x4 is starting off with a positive reputation.
97-up uses the metric bolt pattern and won't interchange with older 5 hole rims.
[font color="green"]1995 F-150 Supercab XLT 4x4 302 M5OD 8' bed [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old 08-08-2002, 02:14 PM
honney honney is offline
honney is starting off with a positive reputation.
5 on 4.5 for an F150?? I think you need 5 on 5.5 but you could probably find either as some newer Exploders got 16" wheels.
Just call Tyres Intl or Natl Tire and Wheel
http://www.tyres1.com/
http://www.natltire.com/
They'll have it or can get it.
Old 08-08-2002, 05:30 PM
thanks for the info.They do need to be 5 on 5.5 bolt pattern.I need to check my typing a little closer i guess.
Old 09-18-2002, 03:21 PM
oleblueford oleblueford is offline
oleblueford is starting off with a positive reputation.
I was wondering if you had had any luck on this?
I had also heard that the Dodge 5 on 5.5 wheels would work, but had also heard the that the center hole might be too small.
Have any ideas where this could be checked out?
Old 09-18-2002, 04:24 PM
Hit Man X Hit Man X is offline
Hit Man X is starting off with a positive reputation.
5 lug 16.5 rims (9) mrcman58 Ford Truck Parts for Sale 9 03-01-2016 11:36 PM
16.5 inch steel 8 lug rim for a spare AlbraiNYa WTB - Parts & other 12 09-10-2015 07:26 PM
8 Lug 16.5 in rims Redneck1465 WTB - Parts & other 17 03-01-2013 05:14 AM
16 inch tires on 16.5 rims fordboy_52 General Automotive Discussion 9 12-03-2009 11:15 PM
Converting 16.5" rims to 16" rims lt dan 1973 - 1979 F-100 & Larger F-Series Trucks 11 05-25-2001 12:43 PM
Tags
16, 165, 2002, 45, 55, 87, f150, ford, hole, lug, lugs, pattern, rim, rims, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
