electrical noise or knock on slight acceleration - Ford Truck Enthusiasts Forums
Old 08-18-2012, 07:09 AM
Q'man Q'man is offline
Q'man is starting off with a positive reputation.
I have an electical sound or knock like when welding and you get the arc of steel sounds like a sizzle almost how truck sounds. Started a while back only going up hills when engine needed gas when hit gas or let off it quit. Now it does it on any slight grade. 2005 fx4 5.4 all plugs done at 96000 truck has 105000 noise started about 98000. No codes come up had it to 2 dealerships cant figure it out. Any suggestions
ford 4.9 cold start knocking noise blue924.9 1987 - 1996 F150 & Larger F-Series Trucks 3 01-28-2014 09:11 PM
Bad Knock When Cold Startup Firminator_X 1997 - 2003 F150 8 01-15-2010 11:44 AM
Slight Knocking sound. 1977F250Custom4x4 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-05-2009 04:16 PM
What is that noise? JT150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 03-04-2007 11:30 PM
Sort of a knocking noise Ranger256 Escape & Escape Hybrid 10 12-30-2005 01:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
