This is prolly a 1 page thread at most
Thanks for the well wishes on the inspection. I'm pretty detail oriented, so I'm sure I won't miss anything. Then again, a do-over wouldn't be that bad.
Andre, you have to be careful where you stick duct tape. It can be hard to get off of certain surfaces.
Roy- I need a break from the heat. sending it your way... Effing bees are trying to do another hive... Time to get more poison...
Doug - As long as she does want to use rear end lube on you, it's all good.
Killer250 - What is the year and model and engine of your truck. We will do our best here to help you and at least give you an easy link to click to the correct section if we can't. Here is where it gets tricky. I don't know about ALL trucks and configurations, but I would check the main fuses under the hood and make sure they are good. At this point, I bet you are looking for one of the larger fuses blown and that slightly burned on all fuses means you probably have a nasty short. So if you see a lage fuse blown, be careful putting it back. A direct short on those could be quite nasty and bright.
Andre - Nice props.
Andre - Nice props.
Take one for the team, Doug !
Received 3,995 Likes
on
I work 12 hour shifts and am home daily. I rotate between days and nights. Usually, I have 14 days off per 28 day cycle. With the units down for repair recently and the new unit going in, I have been spending a lot more of my time at the plant than at home. I'm blessed to have a job to complain about. Working too many days and hours is a better problem than not enough hours and days. I don't need or want the extra hours or money, but I am not going to do this for free either.
