Fuel lines - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Fuel lines
Old 08-17-2012, 06:57 PM
BreeAna BreeAna is offline
BreeAna is starting off with a positive reputation.
Exclamation Fuel lines
My boyfriend's 1994 Ranger 2.3 studders really bad once throttle is engaged. We've changed out the fuel pump 3 different times, and it still hasn't helped. Also, we've changed the fuel filter-hasn't helped. Now he has the fuel line that goes from the engine to the fuel filter, and he doesn't know how to disconnect the quick connector. He already de-pressurized it, but says if he takes the hose off, he won't be able to get it back on. HELP PLEASE.
It seems that it runs alot smoother the higher the RPM, but doesn't quit completely. During the mornings whenever first cranked and ran, it runs very smoothly, but studders as soon as it heats up to temp. I'm pretty witty when it comes to automotive repair, but Fords are not my forte. I know that you do not have to have the tool for the connectors, but I don't recall what I was taught in my ASE certification classes since it's been a few years. How-to help is needed ASAP.
Old 08-17-2012, 07:55 PM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
Have you thought about checking the timing belt, the plugs, wires and coil? And a cheap set of fuel line disconnect spools beats wondering how to get them apart.
Old 08-18-2012, 01:58 PM
Yes, we have looked at everything, and have concluded that it's either a fuel delivery problem, or a firing problem, but the spark plugs and wires are showing no signs of stress. We finally got the fuel line on that he bought, but it still hasn't fixed the problem.
Old 08-18-2012, 07:38 PM
Phinxter's Avatar
Phinxter Phinxter is offline
Phinxter is gaining momentum as a positive member of FTE.Phinxter is gaining momentum as a positive member of FTE.
Quote:
Just because it looks ok doesn't mean it is ok. If it is doing this under load I would suspect an ignition related problem.
Old 07-05-2014, 10:33 PM
william Hanes william Hanes is offline
william Hanes is starting off with a positive reputation.
When changing the fuel pump on a 1994 ranger having problems with the plastic ring that holds the pump in place
Old 07-06-2014, 12:57 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Your timing could have jumped, and the symptoms of that would match your situation exactly.
Old 07-06-2014, 07:46 PM
drb1956 drb1956 is offline
drb1956 is starting off with a positive reputation.
shudder
When my MAF sensor went bad(If your 94 has one being OBD1), my truck would start , kinda idle OK, and if you gave it throttle, it would cough and choke itself till it would die. But, it would always start, again and again. Food for thought...
Old 07-08-2014, 06:04 PM
Phinxter's Avatar
who dug this old thread up?
Studder on accel Headviking 6.0L Power Stroke Diesel 29 08-17-2015 12:27 PM
Hesitation, Skipping at Low RPM's (long) Swanolck 1999 - 2003 7.3L Power Stroke Diesel 44 06-03-2015 10:10 AM
1999 Expedition 5.4L No Start - No Voltage to Cam Sensor??? cswett Expedition & Navigator 67 05-31-2015 01:26 PM
please please help!! 2000 expedition bad studdering and misfire malburg2009 Modular V8 (4.6L, 5.4L) 7 03-07-2015 01:14 AM
7.3 Leaking a little Oil and a Possible Fuel Leak? RedDevil460 1999 - 2003 7.3L Power Stroke Diesel 5 01-11-2014 09:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
