97 f250 460 pcv valve help. - Ford Truck Enthusiasts Forums
Old 08-17-2012, 03:33 PM
rock15t rock15t is offline
rock15t has a good reputation on FTE.rock15t has a good reputation on FTE.
I've got a 97 f250 hd w/a 460. The PO was a real winner. The pcv valve isn't plumbed into anything and i know thats not right. I've got a bigger plastic vacuum hose coming from the throttle body going to the canister purge valve solenoid.
My question is, does anyone have a truck like mine with the screw in pcv valve that has a picture of the vacuum t that the pcv valve is supposed to run to? Or even a part number?
I've been to the local salvage yard and have came up empty. I went to the dealerships around me and all they have diagrams of are the 5.0/5.8 and they haven't been any help for anything.
Thanks
Old 08-17-2012, 05:47 PM
BrianDguy BrianDguy is offline
BrianDguy is starting off with a positive reputation.
It is a single vacuum line that, from your intake manifold, will run like this
Intake manifold (against firewall), 'T' at PCV, 'T' at purge solenoid, then end at the charcoal can under your battery.
Pcv Jly154 1987 - 1996 F150 & Larger F-Series Trucks 4 09-25-2015 09:20 PM
5.4L 3V Valve Cover/PCV CurtSD Modular V8 (4.6L, 5.4L) 1 08-26-2014 05:17 PM
Bad pcv valve causing pinging and loss of power? BearFootCustom 1987 - 1996 F150 & Larger F-Series Trucks 7 08-09-2013 10:30 PM
1989 f250 351 windsor PCV valve drjoe171 1987 - 1996 F150 & Larger F-Series Trucks 3 06-13-2012 10:54 PM
PCV Valve Ricky Cox 1987 - 1996 F150 & Larger F-Series Trucks 4 05-30-2012 12:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
