What now?????? - Ford Truck Enthusiasts Forums
What now??????
Old 08-17-2012, 02:57 PM
rigrunner rigrunner is offline
rigrunner is starting off with a positive reputation.
What now??????
I bought a used 04' 250 with 200k miles. I have deleted the egr, flushed the cooling system, replaced the ICP, IPR, and pigtails to both. The FICM has been repaired at "circuitboard". It came with a SuperChip programmer and I have tried stock & performance couple of times but is now in stock. In June I tried to pull my boat, (23ft=2-3 tons) and the truck went crazy. I bought a SCII and was monitoring WT and EOT. The EOT went 25-30 degrees over coolant temp. After about 3 miles I was looking at 210WT and 250EOT and no place to pull over. About 1 1/2 miles up was a traffic light and store. As I was pulling into store steam went everywhere and truck died. Lifted the hood, coolant everywhere. Towed to repair shop. After about 1hr it would start. Degas bottle had crack and t/s hose had blown. After repair I noticed no power. temps were below 190-coolant & 200- oil. After getting home I checked ICP & IPR. IDLE READ ICP=628psi IPR=77.6%. 1st thought-oil leak. Mech. test drove and read real time data. He said O'Rings in oil rail may be leaking because of code p0263(cyl 1 contribution/balance. I pulled valve covers, pass side was dripping, drive side was pouring. Replaced all oil rail O'Rings. Started up, no leaks. ICP=648psi started, IPR=24.7% cold idle. ROAD TEST, op. temp. at 30mph the ICP=947psi, IPR=34%, then when I fueled up the ICP=677psi, IPR=77.6%. Let off the fuel, ICP=1100, IPR=34%. Then the IPR went to 77.6% and would not change. Could I have melted the connections or have I ruined my engine. Should I start total teardown to HPOP? I just need a starting point and possible check off list. I almost sold the beast when I tackled the ICP & IPR, now I almost wish I had. Thanks in advance for any direction.
Old 08-17-2012, 04:19 PM
berick's Avatar
berick berick is offline
berick is gaining momentum as a positive member of FTE.
Ouch.... that sucks! I'm going out on a limb here and saying the least you will be doing is replacing an oil cooler!
Old 08-17-2012, 04:40 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
IPR #'s area too high, looks like HPO leak some more. Maybe a pinched o-ring or somthing going back together. Do you know if it's early or late '04? Late has ICP on passenger side valve cover, early will have ICP under turbo.
Old 08-17-2012, 05:27 PM
The ICP is behind the turbo as is the IPR. Just replaced 6/12. Numbers were good then. I only replace the O'rings under the nipples and they did not leak when I cranked it before I put the valve covers on.
Old 08-17-2012, 06:25 PM
Been a rash of these lately (mine included) but I would pull IPR and check screen. Seem like someone else here had one (early '04) acting similarly and it was an o-ring between the HPOP and the cover. The 1100/34% sounds ballpark ok and it just changed suddenly. Might have been when IPR swallowed screen or it spit out the o-ring in the pump cover. It's not uncommon to loose the IPR screen after working in the oil cooler resivor area. Just what-iffing here, hard to be certain over the computer.
Old 08-17-2012, 08:08 PM
Quote:
Rusty,
Just got home from work and let truck idle for a while. Fired right up, #'s looked like= IPR-28.1%, ICP=632psi, WT-146. Let it idle while I fed chickens, came back WT-188. REved to 1k rpm, IPR-26.7%, ICP-675psi, 2k rpm, IPR-35.5%, ICP-1000psi. Said to self, maybe fixed itself. Put in reverse and the dangest thing happened. The IPR started climbing until it got to 77.6%, put the truck back to park and it dropped back down to 27.8%. I did this several times, same result each time. Did not move, just put in reverse. It there a connection or loose connection here? Or is it cursed and needs to die. I can record this on my wife's phone if questionable. Thanks
Old 08-17-2012, 09:36 PM
I've never seen that, not sure what to think lol! I'll have to study on that one awhile. Maybe someone else here knows where to look? Are you using a ScanGauge? Can you monitor battery volts and VRef while this is happening?
Old 08-17-2012, 11:16 PM
I have a SGII and will go right now and monitor batt volts. Not sure what VRef is but I have entered most x codes and will see if it is in there. Thanks for the help??
Old 08-18-2012, 02:49 AM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is online now
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Vref is the voltage the sensors operate on. Should read 4.95 to 5.0V.
KO=4.9 LI=4.9 HI=4.9 OR=4.5 - 5.5 VOLTS Reference Voltage
Old 08-18-2012, 10:25 AM
Rusty,
My pc crashed last nite and had to run recovery. My 1st question from last nite came from looking for VRef on my ScanGauge II. I guess I have not loaded VRef into Xgauge, BUT I came accross SYN=0 while idling. Is that value susposed to be 1 if cam and crank are in syn? Mine is showing 0. Also had these codes, p0264, circuit low-inj #2, and P0676-circuit fail, glow plug #6. After warmed to op temp, VDC= 13.2-14.0vdc. At idle I can increase rpm up to 2500 and IPR & ICP operate in normal range, pull out on street and accel. and in seconds the IPR=77.6%, ICP stays in 650-775psi range. Pull in drive, IPR=77.6%, ICP=650psi. Put in park or neutral and pat accel pedal and IPR starts decreasing until reaching 27.6% and stays there at idle. I can increase rpm and IPR & ICP act normal. Put in ANY gear and IPR increases to 77.6% and stays there at idle while in gear. VDC stay between 13.2-13.7vdc. Put back in park/neutral and IPR decreases back to 27.6%. I am lost as a red snapper in a bath tub.
Old 08-18-2012, 11:45 AM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
high ipr% at idle make me wonder if the pump is going south. not unheard of on an 03/04
Old 08-18-2012, 12:21 PM
Quote:
Cheese,
I guess you are talking about the 77.6%, but when I 1st start it is at 27.6%, what confuses me is the increase when I put it in gear and the decrease when I put it in park or neutral without every increasing rpm.
Also, do you know what sync for cam/crank should be on ScanGaugeII
0 or 1? My SGII is reading 0.
It's 1pm cst, been called in, will be back Sunday evening, 8/19/12 around 6pm
Old 08-18-2012, 03:54 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Im kinda thinking the same as Cheezit on the HPOP
YOU NEED A NEW OIL COOLER ASAP Regaurdless you have 2 problems going on Minimum
Now lets run a HPO Test very important you do it just like this below
OPERATING VALUES
Just make shure the numbers are taken exactly like this
Truck in PARK OR NEUTRAL all times during test
ECT at 190* or close to And EOT at 185* or higher
A/C OFF
#1-------KOEO=Key On Engine Off =record value and POST IT!!
#2-------Low Idel (truck idel on its own)=record value and POST IT!!
#3-------High Idel (2500RPM)=record value and POST IT!!
POST Values for ICP & IPR% For each #1,2,3 above
so you will have 3 values for Each Sensor/Valve
Are you With Me???????^^^^^
And do you have an OEM Oil Filter and OEM Oil Filter CAP????this is very important if unshure just ask but must be shure what you have for these Items
After you get those Operating values might be a Good Idea to start to research and get the Parts together to do an AIR TEST on the HPO System
Old 08-19-2012, 06:17 PM
OPERATING VALUES
A/C OFF
I have an Motorcraft Filter and told I have the OEM CAP( has a pentagon shape on top, about 2" high, checked after reading other post )
Test: Truck in park, warmed up 20 mins, A/C off
ECT at 188* and EOT at 186* on SCII
IPR
KOEO=14.4%
LOW IDLE=24.7%
HIGH IDLE=54.7% 2500rpm
ICP
KOEO=11 PSI
LOW IDLE=638 PSI
HIGH IDLE=1336 PSI 2500rpm
Last edited by rigrunner; 08-20-2012 at 11:55 AM. Reason: incorrect data for 2500rpm
Old 08-20-2012, 11:25 PM
Went by diesel shop today and cap is OEM. I 1st put the #'s for 2000rpm in for 2500 and edited that. Still no assistance?
P0264 still shows up after clearing every time cranked up.
Slow to build ICP daddykitty 6.0L Power Stroke Diesel 3 12-23-2016 07:58 AM
Still no start. Ideas??? phantomphixer 6.0L Power Stroke Diesel 19 04-06-2016 09:23 PM
2005 6.0 no start when hot Bill Pittman 6.0L Power Stroke Diesel 10 01-13-2015 08:03 AM
ICP default on scangaugeII? JOBPSD1963 6.0L Power Stroke Diesel 33 07-28-2014 07:40 AM
Could it really be the HPOP? lupuseven 6.0L Power Stroke Diesel 0 12-26-2013 03:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
