Dana 80 Limited slip or Locker ? - Ford Truck Enthusiasts Forums
Old 08-17-2012, 08:15 AM
J R Sparky's Avatar
J R Sparky J R Sparky is offline
J R Sparky is starting off with a positive reputation.
Question Dana 80 Limited slip or Locker ?
I have a 97 DRW, 5 spd. man tranny with 5.13 and an open differential. On some boat ramps I need more traction to crest the ramp. Can someone recommend a "drop in" LS, Locker or Posi traction unit?? Appreciate any help guys, thanks.
Old 08-26-2012, 01:59 PM
J R Sparky's Avatar
Dana 80 Rear End
Surely someone in the group has worked with a L/S rear end in a Dana 80 housing. BUMP.
Old 08-27-2012, 08:06 PM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is gaining momentum as a positive member of FTE.wyoming4x4 is gaining momentum as a positive member of FTE.
common L/S.
the power lok limited slip is a good start. easy to rebuild and common in the dana 80. not sure what is out their available for these axles. but i really like a air locker. full posi if needed and open diff in normal operation and just driving around and good on fuel mileage. i run a air locker in my dana 60. my dana 80 has a power lok limited slip. the only downfall of a power lok limited slip is the clutches wear over time but the power lok limited slip is probably the best of the clutch style limited slipes. if just using for normal driving should do well. but if running big tires and hrspwr might think about upgrading to something better. good luck.
Yukon Lockers Daleksandrovich Offroad & 4x4 12 06-21-2014 08:51 PM
Power loss when trying to pull boat up launch ramp!!! Morgueman 1997-2006 Expedition & Navigator 8 01-05-2014 12:04 AM
Do I need air lockers? DieselVol 1999 to 2016 Super Duty 55 06-02-2012 07:07 PM
1990 Bronco, weak points? is my front axle OK? ErrorS Offroad & 4x4 11 01-24-2010 05:56 PM
Theoretical question about lockers. cyclegrip Offroad & 4x4 22 02-05-2009 10:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
