trailer lights not working
Old 08-17-2012, 03:59 AM
worm0479's Avatar
worm0479
worm0479 is offline
looking for info on where on the truck can i locate the relay packs or fuses for the plug for the trailer. trailer works for everyone else but mine half works(drivers side brake light doesnt work) OR MAYBE A PLUG SOMEWERE IN BEtween has came lose. need to get on highway in a couple of days need help
Old 08-17-2012, 07:28 AM
riverrat41's Avatar
riverrat41
riverrat41 is offline
Get your book out and turn to the fuse panel section.You will find fuses that pertain to trailer lamps.Cannot remember which #.
Take a test light to the plug and check your output on signals.
Old 08-17-2012, 12:53 PM
worm0479's Avatar
worm0479
worm0479 is offline
well the fuse is ok.
i was told there fuse banks or relay banks that handle the extra load of a larger trailer lights and electric brakes all lights work ecapt the running lights on one side and the brake light on the other
Old 08-17-2012, 01:02 PM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
Is it the original 7 pin or a 6 pin connector
Old 08-17-2012, 02:31 PM
worm0479's Avatar
worm0479
worm0479 is offline
it the factory fat round pin and the small 4 pin. both have the prob
but just found out the bulb for the brake light was bad but the running light are not powered even bought the trailer pin test plug for both and thats what it shows.
it has to be somewhere between the plug and the front looked at wires seen no frays
Old 08-17-2012, 02:34 PM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
I didn't see it posted but did you check the fuses under the hood? driver's side along the fender against the firewall. THere are fuses there for trailer lights and power as well.
If this check out then I would start at the connector at the back of the truck and open it up to make sure nothing got pulled loose. Then go back from there to make sure nothing is cut. The trailer harness goes along the drivers side frame rail.
Old 08-17-2012, 10:54 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
What he said...^^^^^^ Billy bob has your solution. Mine had same symptoms and I had two blown fuses under the hood in the tow control box.
Old 08-19-2012, 03:59 AM
worm0479's Avatar
worm0479
worm0479 is offline
well checked under hood and the only thing i could find was two 2x3 black boxes that have relays in them no fuses. are these what ur talking about. do i need to ohm them out?????
Old 08-19-2012, 09:52 AM
BillyBob69's Avatar
BillyBob69
It should be about 8 inches by 5 at the top / back corner, drivers side. Your manual, if you have one, will show a diagram of fuses and relays. The top is hinged on the firewall with a little lift tab on the front that opens it up.
Now... that being said... I think in 01 or 02, they did away with that power distribution box and put it all under the dash. In the diagram tho, it will list trailer lights for tail, turn, brake, 12v power and back up. If you don't find it wait a little bit. I'll post a pick of mine.
Old 08-19-2012, 10:06 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,102 Likes on 2,164 Posts
what truck are you working on?
some have trailer fuses under the hood, some under the dash.
Old 08-19-2012, 10:12 AM
BillyBob69's Avatar
BillyBob69
Here is the box, I marked the tab you pull on a little to open it.
Old 08-19-2012, 02:52 PM
carltonwebb
According to your profile, u have a 2003 model. It is pretty important to identify the year of truck you have. If that is the truck you are working on, I do not think you have the underhood power dist box. All of your fuses are under the steering column if I remember correctly. I think some of the members have had some issues with connectors under the truck corroding.
Old 08-19-2012, 03:25 PM
JT250's Avatar
JT250
JT250 is offline
Yes all 2003 fuses are under the dash. Make sure all the trailer ones are good then start with a test light at the back connector. If you don't have running lights there it might be at the back of that connector where the harness plugs in. Could be corroded.
Old 08-19-2012, 09:44 PM
worm0479's Avatar
worm0479
worm0479 is offline
Sorry guys I thought all 99-03 7.3 were the same.
Mine is a 2003 extra cab not crew 4*4 fx4 auto
And this must have been when they moved it inside the cab.
Going to have another look under the dash and try to locate the bad fuses.
Will state that my truck was a boarder line total that was only two months old with 3300 miles on it the truck was put back together by a bunch of votec college kids try to pick up an extra class Bc the truck has a "diamond" in the frame they never even fixed the frame the driver wheel sits back 3/4 inch further back and they welded a pair of washers on the bumper bracket just to mount it. Praying that some idiot pulls out in front of me ( hopefully wearing there seatbelts they have insurance so one day I can fix it) its prob got all kinds of stuff wrong.
Thanks guys will report back later
Old 08-20-2012, 12:13 AM
Larry_the_handyman's Avatar
Larry_the_handyman
Larry_the_handyman is offline
I had a similar problem with my trailer lights last year. The chassis wiring harness had power but I lost connectivity in the middle of the wire between the 7 pin and the grey weather pak connector to the chassis harness. I ended up having to replace the 7/4 pin connector. It was about $140 at the dealer, but it's better than towing in the dark (or with those little test clips holding wires together).
Quick Reply: trailer lights not working
