head gaskets
head gaskets
Ok I think I have a blown head gasket on 94 4.0 on left side. no water in oil, nothing from tail pipe.
anyhow I just looked at autozone for gasket kit and it recommends new head bolts. Are these torque to yield bolts like the late model diesels (1 time use)?
does anyone know if actual studs are available and at what cost? the replacement bolts cost about $40 a set.
if its a cracked head, anyone have a source for them?
thanks hank
thanks hank
You can get studs from ARP.
The bolts are torque to yield, do not attempt to reuse them.
If you buy new heads, there are a few choices, try to find some that use hardened seat inserts, most stock heads are pretty well shot by 150,000 so if you have more that that, pretty much all of your stock valve seats will be shot whether the head has cracked or not. If it hasn't cracked, you still need new seats put in, which will probably cost nearly as much as a new head that already has good seats installed. Heads that have hardened inserts are better than stock.
I ordered my heads through my machine shop, I can't remember the brand.
Get the Fel-Pro or Victor Reinz head gaskets. Replace the upper and lower intake gaskets, and all injector O rings while you are at it, and replace the PCV valve and inspect all hoses, replace any that are brittle or cracked.
mfp4073
1983 - 2012 Ranger & B-Series
22
06-15-2014 10:35 PM
Wakeboarder141
38
06-26-2004 10:45 PM
