how to remove dash cover to install switches? -- 99 F350 Lariat - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-16-2012, 10:24 AM
eyyu eyyu is offline
Bricks & PSD
eyyu is gaining momentum as a positive member of FTE.
Iím getting ready to add a few manual switches to my new 99 F350 truck. If you did something similar to the factory dash cover as shown in the picture below, please let me know how to either remove that little square thing so I can install the switches on it or, if itís not separable from the rest of the cover, how to remove the entire cover without breaking any plastic parts? Iím mainly thinking about a TC lock-up, a Exhaust brake, maybe a GPR manual switch. I want to place those switches in the right spot and leave room (if any) for future expansion. What do you all think? Thx. Erwin
Old 08-16-2012, 10:37 AM
Christof13T's Avatar
Christof13T Christof13T is offline
Christof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant future
My switches are in the same spot your talking about..
Have a switch for the idm fooler switch, and 2 for the tc lockup and exhaust butterfly.
Mine are actually mounted to my 4x4 selector switch panel.
You can get switches to your liking... and cut holes with a dremmel or something...
I just have simple toggle switches so they mounted in drilled holes.
Xtof
Old 08-16-2012, 10:55 AM
timmyboy76's Avatar
timmyboy76 timmyboy76 is online now
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
pull the bezel, snaps right off. I have an extra fuel gauge, in that same area.
Old 08-16-2012, 11:09 AM
Bricks & PSD
Quote:
How? I ran a needle along the grove and it feels like one piece withe the rest of the dash cover.
Old 08-16-2012, 11:11 AM
Deluxe06's Avatar
Deluxe06 Deluxe06 is offline
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
Here's a little wright-up on how to remove you dash panel, if need be.
Old 08-16-2012, 11:32 AM
Bricks & PSD
Richard, That's very usefull information. I'll keep the write-up in my collection. Anyone knows if the square thing alone is removable? Erwin
Old 08-16-2012, 11:56 AM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Quote:
No, it's molded into the bezel. You would have to cut it out with some sort of tool. I cut out mine and then fashioned a metal cover plate...mounted everything to the plate and then screwed the plate to the dash. This way I can access the wiring without having to remove the bezel again.
Old 08-16-2012, 12:32 PM
Bricks & PSD
Greg, Thx for getting me the right answer.
Old 08-16-2012, 01:43 PM
danskool's Avatar
danskool danskool is offline
Go Bills !
danskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to behold
SpringerPop's Upfitter Switches
The switches.. Thanks to SpringerPop.
Old 08-16-2012, 02:06 PM
CSIPSD's Avatar
CSIPSD CSIPSD is offline
CSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to behold
Dont just pull it out... You have to remove the stereo first and remove two bolts in there...
Old 08-16-2012, 02:24 PM
Bricks & PSD
CSIPSD, just where on earth did you find those buttons with indicator lite? How about the mounting plate? WOW. beside all the expertise in PSD technology, we have some serious artistic minds here!
Old 08-16-2012, 02:28 PM
Bricks & PSD
looking more carefully at your picture, now I see two more switches (toggle kind) beside the 6 on the plate. What are those 8 switches for? very nice setup with the gauge under dash gauge pod and CB radio.
Old 08-16-2012, 03:02 PM
CSIPSD's Avatar
As to the switch plate... It came from a boat shop in Astoria Oregon... Its worked fine over the years however there is no way to label the switch which is a pain.
The ones below are for my strobes and mirror heat. They were there before I installed that switch plate so I am stuck with them down there, or have holes.
Old 08-16-2012, 04:11 PM
VegasFordSD's Avatar
VegasFordSD VegasFordSD is offline
VegasFordSD has a great reputation on FTE.VegasFordSD has a great reputation on FTE.VegasFordSD has a great reputation on FTE.VegasFordSD has a great reputation on FTE.VegasFordSD has a great reputation on FTE.
which one drops the landing gear?
Old 08-16-2012, 04:33 PM
F250_'s Avatar
F250_ F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
Here's a starting point for similar switch mount options. Marine Switch Panels - iboats
And this company might also have some things you might be interested in. http://www.paneltronics.com/ip.asp?e...s=OEM%20Panels
truck stranded, starts every time, won't stay running eyyu Large Truck 5 08-22-2016 07:58 PM
Diesel general question - Stranded, truck starts, wont stay running eyyu 1994.5 - 1997 7.3L Power Stroke Diesel 4 08-15-2016 02:41 PM
general diesel question - truck stranded, starts every time, won't stay running eyyu 1999 - 2003 7.3L Power Stroke Diesel 5 08-15-2016 02:39 PM
Seeking input on buying a new 88 F600 eyyu 1987 - 1996 F150 & Larger F-Series Trucks 5 04-19-2016 11:41 AM
need confirmation before I open up my AC system, data included eyyu 1999 - 2003 7.3L Power Stroke Diesel 19 06-12-2015 06:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
