hub locking problems
Old 04-11-2015, 12:37 PM
sudsmcduff's Avatar
sudsmcduff
sudsmcduff is offline
was not able to turn driveshaft by hand, cleaned and greased hubs with guzzles page instructions. was ok for a few months but now still cant turn driveshaft. is this the point where i should buy warn hubs? do i need to check for vacuum leak? thanks. i do use 4x4 a handfull times a year.
Old 04-11-2015, 03:09 PM
mueckster's Avatar
mueckster
mueckster is offline
Pop the ESOF hubs out and see if the driveshaft turns freely with them removed. If so, replacing them with manual lockers would be more cost effective. A vacuum leak would not cause hub engagement. Vacuum apples the hubs.
Old 04-11-2015, 03:24 PM
sudsmcduff's Avatar
sudsmcduff
removed and pushed down on springs inside a few times. all is good now. i see riff raff has 2 kinds of warn hubs, do i need the premium warn hubs? or go with the cheaper, thanks
Old 04-11-2015, 03:41 PM
M-S-G's Avatar
M-S-G
M-S-G is offline
I replaced warn non-premium with MileMarker. Way better, all metal and $99 on amazon. Highly recommended.
Old 04-12-2015, 12:04 AM
crop harvester's Avatar
crop harvester
crop harvester is offline
Warn pemium's has always performed well on our several 4x4's.
Old 04-12-2015, 10:45 AM
whitetmw's Avatar
whitetmw
whitetmw is offline
Annual maintenance will keep the operational indefinitely. I do mine in July, that way they're ready for December.
Old 04-12-2015, 07:34 PM
sudsmcduff's Avatar
sudsmcduff
I think my main issue is last year I had to drive in 3 feet of waves at pismo beach to go pick up a friend at the entrance. Used salt away when I got back but didn't get it all off. My rear brakes had issues dragging few months back
Old 04-13-2015, 10:18 PM
M-S-G's Avatar
M-S-G
M-S-G is offline
Ouch. Salt water.
Pro tip: take them out and soak overnight in your used motor oil bucket.
Old 04-13-2015, 10:29 PM
sudsmcduff's Avatar
sudsmcduff
Originally Posted by M-S-G
Ouch. Salt water.
thanks for that, i will
strat875
Modular V8 (4.6L, 5.4L)
12-01-2015 10:26 PM
mackstruck
1999 to 2016 Super Duty
09-05-2011 10:10 AM
adam10
04-07-2010 05:54 PM
RShaips
12-11-2005 01:31 AM
sjankowski
11-16-2005 03:23 AM
Quick Reply: hub locking problems
