It's under the middle of the rear axle. I need it to drop about 4 or 5 inches. I think I'm gonna put the axle on cinder blocks and use the jack with a 4x4 from the jack to the frame to lift it and raise my jack stands.
ahh I was looking at the last pic you had posted.... Jacking the frame is about your only option, but instead of putting a 4x4 between your jack and frame dont kill your self, put something under your jack.... like a cinder block
Yeah, I came up with a new plan today, and it's just what you said, a cinder block under the jack. Except I need about a foot so Imma stack two, then put the jack on top.
I wish I had a forklift!
I ended up using my engine hoist to lift up the truck, then raised the jack stands.
Then I put the shackle in place to see what the angle was when the springs are uncompressed.
I'm going to paint the shackles tonight and put them on tomarro.
Your rear shackle mount isn't going to work just by flipping it upside down like that. It's too high above the frame rails and will hit the bottom of the bed.
My bed is rotted out in the bottom so I'm going to have to repair it. I was planning to raise it up kinda like making a hump where the hanger is.
