Engine Choices
I paid $600 for a running 1990 ford crown vic. 5.0L, AOD four-speed automatic and took a whole bunch of misc. stuff out of it. I rebuilt everything, but could've had it in the truck and running for about a grand if I'd wanted too. It'll be the little stuff like linkages, exhaust mods, u-joints, shifter, etc. that push up the cost.
Mike
Mike
Hey Ivan,
We've got a 1950 F1 - Started out with a 289 - lot's of room.
We upgraded to a 351W to get a bit more HP - it fits fine but it's a squeeze on the driver's side - exhaust, steering, pedals, brakes - a lot going on there. We put the battery in behind the seat as there wasn't much room left under the hood with the 351W - we also went with a very slim electric fan up front as we were running out of room between the water pump & the radiator. We also had to adjust the cabin floor a bit to put an AOD under there.
It's all doable - just get's a little tougher as you increase in size.
Welcome aboard!
Ben in Austin
Welcome aboard!
Ben in Austin
on
The easy installation is a small block Chevy with a 350TH, but a 289/302 Ford with a C4 is right behind. I've done both. The Ford is a little longer so clearance at the radiator is closer. I don't know what you consider a major mod but engine and transmission mounts will have to be fabricated and a new driveshaft plus you will probably need a new radiator although some have used the original.
Almost any V8 will fit, on the wider blocks, offset the engine to the pass side an inch or two for extra clearance. Header clearance on the driver side will depend on headers used.
The 2C mod motors are the most available/inexpensive/dependable, but be sure to buy an entire donor or get the entire wiring harness fuel tank and or pump and matching ecu at least. The mods respond to hop ups well, performance parts are available. If you plan on increasing HP shop for a PI model with the better heads, adds 50-60 HP over the small heads without making any changes.
klwinter2
07-12-2014 03:19 AM
tiger_698
02-06-2009 04:33 PM
