Ashtray delete 1987-1991 OBS???
Has anyone deleted the ashtray on their 1987-1991 OBS truck? If so can you attach a photo of what you did?
My 1991 F250 4x4 is headed to Baja if and when this craziness ends and in an effort to make my life easier there I am making a few improvements, the last few were a high flow water pump and 120A third generation alternator.
To keep the battery alive for the months I am not there I installed a solar battery tender and it looks sloppy with the astray hanging open. I needed to replace the cigar lighter because it was really crusty and causing the tender to have a intermittent charging issue.
When I removed the ashtray to replace the cigar lighter I found an enormous cavity that can be used to house a switch panel for lights, a kill switch, USB or other gadgets. This just screams for an upgrade.
A/Ox4
08-17-2011 03:29 PM
