Lifting my 1979 F150 thread, with lots of pics - Ford Truck Enthusiasts Forums
Old 08-14-2012, 11:07 PM
460 FORD MAN's Avatar
460 FORD MAN 460 FORD MAN is offline
460 FORD MAN has a good reputation on FTE.460 FORD MAN has a good reputation on FTE.460 FORD MAN has a good reputation on FTE.
Hey guys/gals
I thought I would start this thread to show yall what I've been up to lately. Im lifting my truck by doing a shackle flip in the rear and getting 'like new' 2 inch lift coils for the front.
Truck stats:
1979 F150 Custom 4x4 swb
460
C6
Holley 4 barrel carbuerator
460 Performer high-rise intake manifold
Edelbrock air filter
Dual glasspack exhaust
30 inch tires
Dana 44 front axle
Ford 9 inch rear axle
3.50 gears
I bought the truck a couple months ago for $1300. She's my first 4x4.
Here's a list of things I've replaced:
new Tires
carb. rebuilt
thermostat
chrome thermostat housing
4 inch air filter
valve cover gaskets
new battery
power stearing pump
and p/s hoses
in-line fuel filter
I also got the oil pan gasket, transmission pan gasket, front and rear axle gaskets, but haven't gotten around to that yet.
Here are some pics that I've been taking over the past couple weeks to get ready for the lift..
I just used a wire brush to get the surface rust off. Planning on either repairing the core support or getting one from a j/y.
Next off is the fenders..
Then the hood and inner fenders..
Removed the A/C . I didn't have the compressor anyway.
I gotta weld the hole up.
Then off came the bed. I'm still wire-wheeling the frame.
Here's the before and after I partially wire wheeled the shackles just to see the condition of them..
That was yesterday. Today all I had time to do was get the rear wheels off and put her on jackstands. More pics to come as I make progress. I usually work on her everyday. Tomorrow I plan on dropping the tank and start cutting the rivets off holding the leafspring hangers on. Let me know what y'all think and if you ever see anything I'm doing wrong please let me know.
Old 08-17-2012, 02:38 AM
As far as progress, nothing really worth taking pics of.
Gas tank is off, tires are off, and the shocks are unbolted.
I broke two 3/8 inch and one half 1/2 drive ratchets tryna get the damn shackle unbolted from the hanger. I even used my dremel with a wire brush attachment to clean the threads out and soaked the bolts with WD-40. Still no go.
Any suggestions?
Old 08-17-2012, 03:09 AM
gpence's Avatar
gpence gpence is offline
gpence is starting off with a positive reputation.
BLUE WRENCH!!!!!!!!!!!!
Old 08-17-2012, 04:35 AM
Been thinking of that. I might be able to get a cheater bar on the end.
Old 08-17-2012, 11:30 AM
piratius's Avatar
piratius piratius is offline
piratius is starting off with a positive reputation.
Soak it with SiliKroil (or PB Blaster, liquid wrench, etc) for a day, then try again. You should really be using a breaker bar for a huge heavy bolt, not ratchets! a 1/2" drive, 2' breaker is essential when working on old rusty trucks! (so is putting a big pipe on the end!)
My second choice is an impact gun on one side, and a big wrench on the other. This'll work better if you've already soaked the bolt with penetrating oil.
If you're planning on replacing the shackle bushings, then I'd say hit the end of the bolt/nut with a torch and get them glowing red hot. Let them cool, then just take them off. If you're going to re-use the bushings, don't do this (it'll burn them up!)
If all else fails, then an angle grinder with a cutoff wheel works wonders, I've heard.
-Brad
Old 08-17-2012, 11:41 AM
keiths78f150's Avatar
keiths78f150 keiths78f150 is offline
keiths78f150 is gaining momentum as a positive member of FTE.
Let all the bolts you are going to take loose soak with Break Loose oil. Soak them 3 or 4 days. Worst case, use a torch and heat up the bolts. Then they will come off.
Old 08-17-2012, 08:44 PM
Thanks for the advice guys!
I took a trip to Atlanta today to get the 2 inch lift coil springs.
Scored them for 75 bucks on Craigslist. They're off a 79 Bronco.
They look pink in the pic. But there actually light red, and rust free.
Imma scuff them up a bit and repaint them gloss red.
Old 08-17-2012, 09:47 PM
Nice score. Working on putting 4 inch oils on mine. Just dont let them slip and hurt ya lol
Old 08-17-2012, 10:15 PM
Are you doing a thread on yours?
Old 08-17-2012, 10:42 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
hope you didn't drive too far for the coils, thats only about $15 less than new.
Old 08-17-2012, 11:08 PM
Where at?
I looked them up and found them for about $80 a piece.
Old 08-17-2012, 11:36 PM
well nevermind someone on ebay used to have them for $90/ pair. I don't see them on there anymore. JBG has them for $140, but thats a good bit more. Coil Springs, 1-2" Lift Pair New
Old 08-18-2012, 01:25 AM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
You do know about moving the rear schackle hanger forward, and just not flipping and reinstalling in the same holes right?
3/4 dv sockets/breaker bar with 3 ft cheater pipe, or a smoke wrench the nuts off.
Work on the botton bolt first cause the top bolt will not push out cause the frame will be in the way. And you might as well use the smoke wrench cause the bushings are probably worn out and will not like having the bolts removed.
Any chance you want to sale your front chrome push bar?
Old 08-18-2012, 04:29 AM
Quote:
I'm going to start a full build thread soon. Any chance you would sell your bull bar? PM me.
Old 08-18-2012, 06:30 AM
Why will I have to? To get the correct angle of the shackle?
Lifting my 1979 F150 thread, with lots of pics 460 FORD MAN Offroad & 4x4 1133 04-24-2014 12:41 PM
Fuel pump question 460 FORD MAN 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-10-2013 09:05 AM
Narrowed front clip 460 FORD MAN 1973 - 1979 F-100 & Larger F-Series Trucks 10 07-10-2013 02:37 AM
Coil spring not seating 460 FORD MAN 1973 - 1979 F-100 & Larger F-Series Trucks 5 09-12-2012 12:30 AM
Lifting my 1979 F150 thread, with lots of pics 460 FORD MAN Georgia Chapter 13 09-11-2012 12:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
