88 7.3 diesel oil dipstick length
Old 08-14-2012, 09:00 AM
wrd0225's Avatar
wrd0225
wrd0225 is offline
I would be obliged if someone would tell me the length of the oil dipstick.
I took my 88 F250 7.3 to get the oil changed. I asked if they filled it up because it wasn't full one time before. The attendant said yes and pulled out the dipstick to show me. He broke it as he was pushing it back in. Next, my nephew kicked the the part of the dipstick I needed to measure with out of the truck and lost it. I went to the junkyard to find one. There were no diesels there. The only ones I could find were with gas engines. I got the longest one out of a gasoline engine I could find which seems long enough, but I don't have any measurement. Thanking you in advance.
Bill
Old 08-14-2012, 09:56 AM
bashby's Avatar
bashby
bashby is offline
92 7.3... 28" from where it seats on the tube to the full mark. 1" from full to add mark.
Old 08-16-2012, 01:24 AM
wrd0225's Avatar
wrd0225
wrd0225 is offline
Thanks for the info. I really needed it!!
Old 08-16-2012, 01:28 AM
wrd0225's Avatar
wrd0225
wrd0225 is offline
Would the measurements be the same for the 88 7.3 as the 92 7.3?
Old 08-16-2012, 06:51 AM
tecgod13's Avatar
tecgod13
tecgod13 is offline
The length shouldn't have changed. But make sure the dipstick tube is the proper length as well, or it will sit at the wrong height when inserted.
Old 08-18-2012, 03:07 PM
wrd0225's Avatar
wrd0225
wrd0225 is offline
Thank you very much!!!
Old 08-21-2012, 08:15 PM
wrd0225's Avatar
wrd0225
wrd0225 is offline
I am sorry that I didn't quite understand your explanation. I am still a little confused.
When you say "tube", are you meaning the tube in the engine block or the tube on the dipstick. If yours has a yellow handle, how far from the bottom of the yellow to the full mark.
Also, is there anyone on this forum living in the inland Empire near Fontana or San Bernardino with a 1988 F250 7.3 IDI?
Old 08-21-2012, 10:27 PM
bashby's Avatar
bashby
bashby is offline
I measured from the top of the yellow "hat" on the dipstick that goes around the dipstick tube in the engine block.
The dipstick goes into the tube and has the handle and "hat" attached.
When you insert the dipstick, the full mark is 28" from the top of the tube that remains in the block when the dipstick is removed.
Clear as mud, right?
Old 08-22-2012, 10:49 AM
wrd0225's Avatar
wrd0225
wrd0225 is offline
Clear!!! Thanks again.
One Sock
20
07-30-2019 01:23 AM
jcweis1
03-07-2016 07:55 PM
Ferrellb07
1999 to 2016 Super Duty
09-24-2012 04:51 PM
lrwatts
01-21-2003 06:08 PM
Quick Reply: 88 7.3 diesel oil dipstick length
