88 7.3 diesel oil dipstick length - Ford Truck Enthusiasts Forums
Old 08-14-2012, 10:00 AM
wrd0225 wrd0225 is offline
wrd0225 is starting off with a positive reputation.
I would be obliged if someone would tell me the length of the oil dipstick.
I took my 88 F250 7.3 to get the oil changed. I asked if they filled it up because it wasn't full one time before. The attendant said yes and pulled out the dipstick to show me. He broke it as he was pushing it back in. Next, my nephew kicked the the part of the dipstick I needed to measure with out of the truck and lost it. I went to the junkyard to find one. There were no diesels there. The only ones I could find were with gas engines. I got the longest one out of a gasoline engine I could find which seems long enough, but I don't have any measurement. Thanking you in advance.
Bill
Old 08-14-2012, 10:56 AM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
92 7.3... 28" from where it seats on the tube to the full mark. 1" from full to add mark.
Old 08-16-2012, 02:24 AM
Thanks for the info. I really needed it!!
Old 08-16-2012, 02:28 AM
Would the measurements be the same for the 88 7.3 as the 92 7.3?
Old 08-16-2012, 07:51 AM
tecgod13 tecgod13 is online now
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
The length shouldn't have changed. But make sure the dipstick tube is the proper length as well, or it will sit at the wrong height when inserted.
Old 08-18-2012, 04:07 PM
Thank you very much!!!
Old 08-21-2012, 09:15 PM
I am sorry that I didn't quite understand your explanation. I am still a little confused.
When you say "tube", are you meaning the tube in the engine block or the tube on the dipstick. If yours has a yellow handle, how far from the bottom of the yellow to the full mark.
Also, is there anyone on this forum living in the inland Empire near Fontana or San Bernardino with a 1988 F250 7.3 IDI?
Old 08-21-2012, 11:27 PM
bashby's Avatar
I measured from the top of the yellow "hat" on the dipstick that goes around the dipstick tube in the engine block.
The dipstick goes into the tube and has the handle and "hat" attached.
When you insert the dipstick, the full mark is 28" from the top of the tube that remains in the block when the dipstick is removed.
Clear as mud, right?
Old 08-22-2012, 11:49 AM
Clear!!! Thanks again.
Hey, Dipstick corralch 1973 - 1979 F-100 & Larger F-Series Trucks 13 10-15-2015 05:49 PM
Oil capacity shouldn't be this difficult? Widetrack455 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 07-10-2014 02:33 PM
Oil Dipstick, am I crazy? Knubbler Ford Inline Six, 200, 250, 4.9L / 300 5 06-26-2014 10:00 PM
Excursion v10 dipstick superdave02f552 Excursion - King of SUVs 3 01-22-2014 09:29 PM
broken dipstick in pan moosebrew Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 09-05-2012 08:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
