6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Elaborate on the DTC's?
Old 08-14-2012, 08:49 AM
RM2738's Avatar
RM2738
RM2738 is offline
Can anyone elaborate on the DTC's?
P1639: FORD Vehicle ID block not programmed or corrupt
P163A: FORD: Generator B control circuit
P0603 Internal Control Module Keep Alive Memory (KAM) Error
I've been having some battery issues first thing in the morning, but it starts and runs fine the rest of the day.
Old 08-14-2012, 09:09 AM
senix's Avatar
senix
senix is online now
Received 1,414 Likes on 1,009 Posts
I just replaced my batteries yesterday. So no check brake system message for you?
Old 08-14-2012, 09:12 AM
RM2738's Avatar
RM2738
RM2738 is offline
I've got check battery, engine & ABS lights. System check says "Check Charging System."
Just seems like a lot of DTC's for some week batteries.
Old 08-14-2012, 09:27 AM
senix's Avatar
senix
senix is online now
Autozone/Napa and others should be able to load test the batteries and check the charging and starting circuits for free.
I'd do that right away.
Old 08-14-2012, 12:50 PM
RM2738's Avatar
RM2738
RM2738 is offline
Lube Tech at dealer says its most likely the alternator. The CEL, battery & ABS light along with a slight odor lead him to that. He said its most likely overcharging the batteries. Their diesel tech is looking at it now.
Hopefully it is the alternator since that's covered under warranty and if the alternator is causing battery failure, then batteries would be covered too.
Old 08-14-2012, 01:27 PM
senix's Avatar
senix
senix is online now
If it is just the batteries..the 100 month ones are on sale with a 30.00 rebate.
Old 08-14-2012, 01:54 PM
RM2738's Avatar
RM2738
RM2738 is offline
Sweet. Thanks for the heads up.
Old 08-14-2012, 02:47 PM
RM2738's Avatar
RM2738
RM2738 is offline
Which batteries? Motorcraft?
Old 08-14-2012, 03:21 PM
senix's Avatar
senix
senix is online now
Yes, m/c batts
Old 08-14-2012, 05:11 PM
RM2738's Avatar
RM2738
RM2738 is offline
Yes, m/c batts
Know where I can get the rebate form?
Batteries were bad... Tuner file most likely became corrupt because of bad batteries. Truck thinks it should have dual alternators when it only has one.
Old 08-14-2012, 05:39 PM
senix's Avatar
senix
senix is online now
Your said should have it.
Old 08-15-2012, 05:02 AM
senix's Avatar
senix
senix is online now
djscottymiami
2015 - 2020 F150
16
01-07-2018 04:24 AM
Doug'sdock
12-21-2015 04:18 PM
newbie2
11-22-2015 04:03 PM
JWA
Garage & Workshop
15
01-15-2014 06:43 AM
m0rgan
10-23-2006 01:21 PM
Quick Reply: Elaborate on the DTC's?
