Question on Airbag on my 55' F100 - Ford Truck Enthusiasts Forums
Old 08-14-2012, 08:38 AM
Gibby55 Gibby55 is offline
Gibby55 is starting off with a positive reputation.
I decided to install a Mustang II front end and Thunderbird IRS. Everything is just about done but I was questioning where I should place the generator, valves, and tank for the air ride system. I already removed the gas tank and am going to build a custom one for the rear and I was thinking about putting my air tank where the gas tank used to go and place the valves and generater next to where the battery goes. The frame of the truck will still be lower than all of the components. Any ideas or thoughts before I start building a box for the generator and valves?
Old 08-14-2012, 11:20 AM
das54's Avatar
das54 das54 is offline
das54 has a very good reputation on FTE.das54 has a very good reputation on FTE.das54 has a very good reputation on FTE.
I thought you were talking about installing airbags - as in the things that blow up in your face if you run into another vehicle. Now that would be a tricky mod. OK, back to the regularly scheduled program.
Old 08-14-2012, 04:11 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
If by generator you really mean air compressor, I'd have that out of and as far away from the cab as possible to keep the noise level inside to a minimum. The rest of the components can go anywhere that's handy.
Old 08-14-2012, 09:26 PM
Yes, Air compressor...sorry was working on my generator earlier today and had it stuck in my head. I was hoping some people who have installed bags on their trucks would have some pictures/advice as where they put there components.
Old 08-15-2012, 09:10 AM
Project-55's Avatar
Project-55 Project-55 is offline
Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.
The space where your gas tank went under the cab is a perfect place for all of your air ride stuff.
Unless your cycling the air bags constantly or have an air leak somewhere in the system, the compressor will only operate every once in a while to maintain tank pressure so compressor noise in the cab should be minimal, especially if you have some good sound dampening mat under your interior carpet.
I just finished a 50 F1 and the air system is frame mounted right under the driver seat and you don't hear the compressor run unless the windows are down. I guess thats a testament for dyna-mat which covers the cab floor under the carpet.
Old 08-15-2012, 01:48 PM
Could you send me a couple pics of your setup? My email is ttwinzz@hotmail.com
Old 08-15-2012, 02:13 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
I did similar on my 55. the air tank is under the passenger door, frame mounted, and the Viair compressor is frame mounted under the bed, in the front passenger corner, behind the edge of the running board.
one air line runs to the tank and one air line runs back towards the rear bags. the tank drain is mounted towards the front of the truck,
almost even with the door hinge.
the electric fuel pump is also frame mounted on the inner side of the boxed frame right there too. So on fresh startup (after a week), you might hear something, but its not really noticable. I have a tiny leak that I haven't found, but its days to leak down.
Sam
Wanted 223 6-V Generator Steves55 WTB - Parts & other 1 10-29-2013 02:17 PM
Stealing my own Gas Knothole 6.2L V8 5 07-17-2012 08:00 PM
DIY Headache Rack, Bed Rails, Generator "Holder" frederic 1987 - 1996 F150 & Larger F-Series Trucks 28 01-13-2012 03:37 PM
1963 Generator/other problems 63' f100 1961 - 1966 F-100 & Larger F-Series Trucks 12 05-10-2009 09:43 AM
Fuel Overflowing MikeGV 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-04-2004 10:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
