Hi, I got a new work truck
Very awesome truck! Glad to see another one being put back to use, you'll find it will help your business a lot to have a very distinguishable and beautiful truck. People will look at your business to learn more on the truck where they wouldn't if it was "just a truck".
You can find parts at places like Mid-Fifty or NPD. Thankfully they now reproduce almost everything, I think the chassis is the only thing they don't!
And welcome to FTE Hopefully you found this topic after they moved it, lol
Received 1,353 Likes
on
I have a growing list of things to repair/replace/consider!
Thanks for the warm welcome! I'm pretty geeked out about the truck and do think it'll be great marketing for my business. Plus I'll never have to wish for a bigger truck! I'd been puzzling over how to make a strong 1st impression and set myself apart from the mow-n-blow services, since my horticultural skills and work are quite a bit different. The second I saw this fab work truck I knew I had a great way to make it clear. Eventually I'll have my business name on the doors and the truck will be a roving advertisement too. Sorry if painting on the doors bothers some of you! If it's any consolation I did have a new logo designed in a mid-century style, it'll look great and be done very respectfully.
Thanks for the mirror advice and ideas. I was originally just going to replace the corroded 5" mirrors and see how the visibility was. Though I have been worried about being able to safely maneuver onto expressways (no I'm not taking this big, slow, precious truck on any 65 mph+ freeways) and drive around clients' fancy neighborhoods (lots of luxury vehicles) with those little mirrors.
I got the 5" wide angle mirrors from Mid-Fifty, they said to break out the old ones and pop in the new. That just doesn't work. I called and was told they'd get back to me once they had a chance to try it with original mirror frames. I'm guessing it's easier to do with modern reproductions. I haven't heard back from Mid-Fifty.
A few of you said I should have glued them on. It would have worked fine, but the raw mirror edge would have been exposed, which seems like it'd chip up easily. Too late now anyway, since I smashed out the old ones first.
Anyone want the old mirror frames? I won't be needing them since I'm getting new mirror heads now. More on that in a bit!
That's what those are called!
Unless you're bent on making it look completely original consider some "west coast" type mirrors. There is just no comparison, IMO, in the additional visibility of the larger mirrors with the convex stick ons or the separate wide angle mirrors. I've driven both. FWIW, the Ford script west coast types show up on ebay once in a while.
Welcome - Go find a big truck stop, they usually have an accessory section that will make you drool - Truckers like mirrors so you should find something that will work.
That being said I know you asked how to get the new mirrors into your old heads - Usually when doing a press fit it involves heating one part (The head) and cooling the other part (Mirror) - Glass doesn't respond well to rapid temp changes so I would try heating the head at about 200-225 degrees for twenty minutes or so and the try pressing the mirror in place (The dangerous part of this process is convincing your other half to use the oven for car parts)
#28
on
#29
#30
It does need a new paint job (going with the same color scheme though) and I want to rebuild the redwood bed sides, taller for more hauling and tool attachment points.
I've done some work with handy neighbors helping, but need to take it to a mechanic for a thorough look over. I still haven't driven it far or onto an expressway.
Good luck on your truck search!
