F150 Vibration
Old 08-13-2012, 08:03 PM
fordtrader's Avatar
fordtrader
fordtrader is offline
F150 Vibration
I just picked up a 95 F150 reg cab SWB & its got a weird vibration that I'm having an issue trying to track down, here's what it's doing & what I've done trying to trace it down:
Starts around 15mph, continues pretty hard til around 30, then gets better, only under acceleration & is still there at higher speeds, but not as noticable.
I bought the truck used, its got 77k miles, is a 5.0, auto, it already had new front brake pads & rotors, rear shoes, drums & u-joints
I have replaced the front tires (1 was sepo'd), replaced the rear drums & fixed the rear brakes (r/r shoes were reversed & had a warped the drum)-no help under acceleration, helped a braking issue
sent the driveshaft out & had it rebalanced-no change
swaped rear tires out for other set-no change
checked motor mounts, all seem to be good
check rear end, gears, bearings all appear ok, no chipped teeth, no noises
it's got me stumped....HELP!
Old 08-15-2012, 08:34 PM
sccamper's Avatar
sccamper
sccamper is offline
Do you feel it in the steering wheel or the seat/floor board?
Old 08-15-2012, 08:39 PM
fordtrader's Avatar
fordtrader
Through the seat, and increases with the speed of the truck & not by engine RPM
Old 08-15-2012, 08:58 PM
sccamper's Avatar
sccamper
sccamper is offline
Sounds like the feeling you get with a separated belt in a tire or driveshaft issue. I know you had them checked/swapped but first things came to mind. Is it completely gone when not accelerating? Bent diff yoke, trans output shaft bushing, tire balance?
Old 08-19-2012, 12:01 AM
fordtrader's Avatar
fordtrader
I thought it was a driveshaft too, the truck had new u-joints when I got it, I had the driveshaft rebalanced, no change, I've swapped tires around & rebalanced them, I've not checked the trans yoke, but I dunno how it could've gotten bent, thats next on my list
Thanks for the help, I'll keep the post updated
Cody Przybylski
2004 - 2008 F150
02-04-2019 08:05 PM
makemeknowit
Modular V10 (6.8l)
16
11-04-2018 08:48 PM
miller2706
1997 - 2003 F150
05-10-2009 07:34 PM
fd1109
13
12-05-2007 06:32 PM
RF6004
1997 - 2003 F150
19
06-08-2004 12:00 AM
Quick Reply: F150 Vibration
