100,000 miles - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
100,000 miles
Old 08-13-2012, 07:45 PM
Hunter40 Hunter40 is offline
Hunter40 is starting off with a positive reputation.
100,000 miles
Nothing spectacular but I just rolled over 100,000 miles yesterday while pulling my 15,000 pound fiver. Today the truck pulls just like it did yesterday. It's as strong as it ever was. Only replaced one radiator and one egr on this engine. I'm on my second set of Goodyears but need another set soon. Oil replaced every 5000 miles fuel filters every 10,000 miles. Replaced air filter at 50,000 miles and again today. One windshield replaced along the way. Original manual transmission, clutch, and brakes.
Had oil sampled by Blackstone along the way. Engine always shows higher than normal wear metals, probably because it's always hooked up to the fiver, and it usually has 2-4 % fuel in the oil.
Old 08-13-2012, 08:04 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
My wear metals are always a bit higher for the same reason.
Good show!
Old 08-13-2012, 09:41 PM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
Congrats, that's a good story to hear.
Old 08-13-2012, 10:15 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Great positive story! That should give some of us some hope to be able to join the 100K club.
And if I may point out the Titan fuel tank in which some were noticing to be a common denominator for HPFP failures.
Old 08-14-2012, 09:19 PM
Yeah no problem with my Titan tank. If I ever buy another truck that will be one of the first mods. It's amazing how much $ you can save with the Internet to find best prices along your journey and an extra big fuel tank.
Hunter40
Old 08-15-2012, 09:40 PM
golfmedik's Avatar
golfmedik golfmedik is offline
golfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputation
Thanks for the encouraging post! I love hearing the 'good' things about our trucks....
Not to derail the thread but, is it the condensation in the tank when it is not full that is causing water to ruin the HPFP?
Old 08-15-2012, 09:50 PM
StanleyZ's Avatar
Shouldn't be, the tanks made of some sort of composit plastic. I've had no problems with mine in 50,000 miles.
Old 08-16-2012, 02:18 AM
parkland parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
Quote:
Even plastic tanks can get condensation.
Just sitting there, the temperature changes and air will move in or out of the tank.
Air has humidity.
Old 08-16-2012, 08:49 AM
StanleyZ's Avatar
Air has humidity.
In Georgia air has a lot of humidity.
Old 08-16-2012, 09:13 AM
golfmedik's Avatar
That's the reason I asked the question and the reason I try to keep all diesel tanks as full as possible, to reduce the amount of condensation. Just wondered if anyone else did the same.
Old 08-16-2012, 09:26 AM
slowmans's Avatar
slowmans slowmans is offline
slowmans has a good reputation on FTE.slowmans has a good reputation on FTE.
I do.....unless im on a road trip, I fill mine every sunday. I dont drive it alot during the week, since I have a company truck.
Old 08-16-2012, 10:39 PM
I always keep mine full, theres lots of good reasons to keep it full anyways.
Old 08-16-2012, 10:43 PM
A good invention would be to use a sealed fuel cap, and run a 1/4" vent hose, where the hose end flows air over an AC cooled heat exchanger, and has a small rubber bladder.
When the vehicle runs, it would freeze that heat exchanger, then allow air to freely enter into the fuel tank, once dried.
When the vehicle is sitting, it would expand and contract air into that bladder.
Old 08-19-2012, 04:05 AM
Brandon D's Avatar
Brandon D Brandon D is offline
Lead Foot User
Brandon D is gaining momentum as a positive member of FTE.Brandon D is gaining momentum as a positive member of FTE.
Quote:
I'll throw in my 2 cents and share my doubts that the Titan tank has anything to do with any HPFP failures. I think it would be smarter to note that almost everyone that has a Titan tank puts lots of miles on their trucks. Over these miles I'd say it's quite likely that they've come across some crap fuel at a random station that lead to the HPFP failure. That to me would make a lot more sense. I know it's just what you've heard and is their thought but I wanted to point out the other side to that coin. Thanks
And congrats to the OP on the milestone. Hopefully you can post the same great review when you hit 200K!!
Old 08-19-2012, 07:16 AM
golfmedik's Avatar
I don't doubt that one bit. I was just repeating what the blue oval folks have said in looking for an excuse. I am sure more than a couple of in ground tanks have water leaking into them.
AS for the OP, my work truck('08 F450 6.4L) made it to 114K and then lost the engine due to a bad oil cooler. The truck averaged a little over 20mph during its life. AS you can tell it idled A LOT and took a lot of abuse. Still very proud of it. If you had a way to convert the time to mileage, I am very sure it would be nearing, if not more than 200k of run time. I still love the 6.4s.
08 6.4 WORN ROCKER ARMS AFTER 113,000 MILES NO DPF EXCELLENT MAINTENANCE SANDDEMON08 6.4L Power Stroke Diesel 142 07-18-2016 10:42 AM
Increasing Gas Mileage & Life Of Your Ranger Via Synthetics, Mods, Etc... Critterhunter Ranger & B-Series 8 05-09-2014 10:39 PM
Several issues popping up asquared 6.4L Power Stroke Diesel 17 02-11-2013 05:49 PM
Automatic Transmission Cooling Ford Runner 6.0L Power Stroke Diesel 16 05-25-2012 09:24 AM
What maintenance is a MUST? Brandon D 6.4L Power Stroke Diesel 10 10-08-2011 10:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
