Cab roof lights - Aftermarket - brand recommendation - Ford Truck Enthusiasts Forums
Old 08-13-2012, 12:42 PM
ThirdsACharm's Avatar
ThirdsACharm ThirdsACharm is offline
ThirdsACharm is starting off with a positive reputation.
Hi,
If anyone has put on cab roof lamps and like them, can you share which brand you went with. I put on smoked LED recons. They look awesome. I have 2 that keep going out (and then back on..its odd). I think its related to moisture between the lens and the base. I'm about to drop the headliner and swap 2 of them out for new replacement ones (replaced from Recon at no cost with no fight - their customer service is very good IMO). But thinking while I have it apart, maybe I should swap in a new set?
Thanks,
TAC
Old 08-19-2012, 07:33 AM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
We used to use Pacer. They made OE looking lamps for ford and chevy and were pretty cheap. No one ever brought back their truck to tell us they didn't work, so I assume they are good.
Pacer High Performance
L '99 F350 cab roof clearance lights Supercab 1999 - 2003 7.3L Power Stroke Diesel 6 03-23-2015 10:46 AM
Recon cab lights Ford_Fan1 6.0L Power Stroke Diesel 3 12-30-2014 10:35 AM
Recon cab lights install superdutyon37s 6.7L Power Stroke Diesel 4 12-11-2014 08:21 AM
Cab Lights ThomasRowanJr 1994.5 - 1997 7.3L Power Stroke Diesel 3 12-09-2014 11:32 PM
Need HELP with Recon LED taillights TCAS007 2009 - 2014 F150 12 04-18-2014 06:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
