HELP!!! - Keep Smoking #3 coil pack after transmission overhaul
Hey guys,
Hope you can help me with my current issue on my 2000 v10 excursion.
I just got done <NOBR>overhauling</NOBR> my transmission, had it pulled (new seals on the rear of motor and transmission) I had a transgo shift kit put in and also a new monster torque converter.
Well after its been all put back together, I drove it the other day to work and after it was parked for <NOBR>couple</NOBR> hours I drove to run an errand, the vehicle died, checked my fuses and the 30 amp, pcm ignition fuse was blown i changed it and it blew again, then one of my coil packs started smoking (#3) it was ruined so i changed it and put a new one in and replaced the fuse, after starting up and running for about 30 seconds the fuse blew again and then smoked the brand new coil. I then tried it again with another new coil pack and it also smoked that one.
Whats wrong HELP.......
Thanks,
Thanks,
I bet the wire got pinched, and now it's just laying on something metal, intermittently shorting to ground.
Is that what ya said when your thumb was attacked?! Lol
On a serious note, i agree sounds like you pinched the pink/white wire. I did something similar with my old Bronco, except it was the O/D wire, talk about being pissed after a Fresh rebuild!
r_reed
04-28-2015 02:47 PM
ExcursionBoy1984
08-13-2012 09:52 AM
