HELP!!! - Keeping Smoking #3 coil pack
Old 08-13-2012, 09:29 AM
ExcursionBoy1984's Avatar
ExcursionBoy1984
ExcursionBoy1984 is offline
Hey guys,
Hope you can help me with my current issue on my 2000 v10 excursion.
I just got done overhauling my transmission, had it pulled (new seals on the rear of motor and transmission) I had a transgo shift kit put in and also a new monster torque converter.
Well after its been all put back together, I drove it the other day to work and after it was parked for couple hours I drove to run an errand, the vehicle died, checked my fuses and the 30 amp, pcm ignition fuse was blown i changed it and it blew again, then one of my coil packs started smoking (#3) it was ruined so i changed it and put a new one in and replaced the fuse, after starting up and running for about 30 seconds the fuse blew again and then smoked the brand new coil. I then tried it again with another new coil pack and it also smoked that one.
Whats wrong HELP.......
Thanks,
Luke.
Old 08-13-2012, 09:37 AM
TrdLtly's Avatar
TrdLtly
TrdLtly is offline
TreadLightly
Since this is more specific to the V10 and not so much to the X, you may want to post over in the Modular V10 (6.8l) - Ford Truck Enthusiasts Forums
I would suspect a chafed wiring harness on the left side (passenger) of the engine. Interesting that it is only #3. I am interested in seeing what you find. I would try to carefully inspect the wiring harness loom to see if it is rubbing either: wires against wires or wires against a stud or something.
Old 08-13-2012, 09:52 AM
ExcursionBoy1984
Thanks pal,
This is what I suspect also, I have reposted on 6.8 forum
Demis Fontes Jr
1999 to 2016 Super Duty
08-18-2017 10:30 AM
ExcursionBoy1984
Modular V10 (6.8l)
08-14-2012 09:08 PM
peanutzfarmer
Modular V8 (4.6L, 5.4L)
10-18-2008 09:41 AM
mrpiggy52
02-10-2005 07:07 AM
bhensley
1997 - 2003 F150
10-08-2003 10:40 AM
Quick Reply: HELP!!! - Keeping Smoking #3 coil pack
