how to identify posi rear end?
look at the axle code on the door tag. I think anything that starts with a letter is a limited slip diff. Alternatively you can jack up the rear end and rotate a tire, if they both turn the same way it has some type of locking or limited slip diff. If they turn opposite ways it's an open diff.
on
All that code jazz will tell you what the truck originally came with, yes. But these trucks are old, and have usually been thru several owners. To make sure what you actually have under your truck, jack up the rear end and turn one wheel while observing the other. If the other wheel turns the same direction, you have a limited slip diff. If it turns in the opposite direction, then you have an open diff.
True, putting the old tag back makes about as much sense as wipin' before you poop. But you do have to jack up the truck anyway and it would be a good idea to open it up and take a look inside.
ahha-retired!
03-09-2011 03:43 PM
mikebadass76
02-11-2008 09:46 PM
coplin
08-21-2004 04:23 PM
