1965 ford f100 disc brake conversion - Ford Truck Enthusiasts Forums
Old 08-12-2012, 11:23 PM
65 Ford Truck Man 65 Ford Truck Man is offline
65 Ford Truck Man is starting off with a positive reputation.
I have a 1965 ford f100 and i recently got some spindles from a 1978 ford f150 with disc brakes. I was wondering which kingpins to use on the truck, has anyone done this conversion?
Old 08-13-2012, 12:26 PM
DPhillips DPhillips is offline
DPhillips is starting off with a positive reputation.
If they were the same diameter, you'd have to use the 65 kingpins. They have the anchor bolt in a different location than the 78. That's only if they're the same diameter. If not, you may be out of luck.
Old 08-13-2012, 03:27 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by 65 Ford Truck Man View Post
I have a 1965 ford f100 and i recently got some spindles from a 1978 ford f150 with disc brakes. I was wondering which kingpins to use on the truck.
Has anyone done this conversion?
Since you're going to be installing the 1978 disc brakes & spindles, use the kingpins for them: D5TZ-3111-A = 1975 F100/150 2WD from serial number W40,001 / 1976/79 F100/150 2WD.
Has anyone done this conversion? 100's of member have! There are a gazillion articles inre to this swap here on FTE, but...
You will need more parts than just the spindles, king pins and disc brakes.
1965 kingpins have the spindle pin locking bolt in a different location. You're not using these parts, so don't worry about it.
Old 08-13-2012, 04:29 PM
Okay thanks i will try that and see if it works!
Old 08-13-2012, 10:02 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
If you have 65 beams you need to use the 65 Pins. and they are the same diameter. If you use the later pins they are to far one way as dictated by the king bolt bore in the 65 axle end.
65 is the only year that need the specific pin. all others can use later pins.
Will you be having the pins fitted by using bronze bushings or using nylon?
Garbz
Garbz.
Old 08-13-2012, 11:21 PM
I just tried the 65 kingpins and they are the ones that will work. I am getting brass bushings reamed to fit the kingpins.
Old 08-13-2012, 11:42 PM
The 65 kingpins are roughly 1/8 inch shorter, however it shouldnt make a difference bcz thats only 1/16 inch on each side. The diameters are the same though
Old 08-15-2012, 12:05 AM
garbz2's Avatar
Good!
Garbz
front disc brake conversion kit JosephPatrick 1961 - 1966 F-100 & Larger F-Series Trucks 25 02-12-2017 03:21 PM
Converting To Disc Brakes coopster17 1961 - 1966 F-100 & Larger F-Series Trucks 11 09-10-2015 10:59 PM
Brakes/Parts Questions WebMattR 1961 - 1966 F-100 & Larger F-Series Trucks 12 11-22-2014 11:49 AM
Factory/stock Wheels and Tires for 1965 F100 1965F100(3onthetree) 1961 - 1966 F-100 & Larger F-Series Trucks 114 08-09-2012 09:37 PM
HELP - Wheels for Disc Brake Conversion 1965F100(3onthetree) 1961 - 1966 F-100 & Larger F-Series Trucks 10 04-20-2012 06:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
