Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-12-2012, 10:15 PM
KAMARAL007 KAMARAL007 is offline
Garage is empty, add now
KAMARAL007 is starting off with a positive reputation.
60 F100 Dash ?
I started restoring the inside of the cab of my 60. This might be a dumb question, but how the heck do you take off the control ***** on the dash? I figured they just twisted on or off but I can't seem to figure it out.
  #2 (permalink)
Old 08-12-2012, 11:35 PM
F250racer's Avatar
F250racer F250racer is offline
F250racer is starting off with a positive reputation.
there should be a little set screw you need to take out. For the headlight switch I think you push a tiny button on the bottom on the switch and the whole rod/**** comes out.
__________________
Colin
'59 F-250 Styleside Longbed, 292, 4spd, Rockwell 5.83 dually running gear, custom NP205 overdrive.
"The truck's a Ford and the tractor's green"
  #3 (permalink)
Old 08-13-2012, 04:19 AM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
It depends on the switch/cable..
headlight switch: pull switch to on position then from backside of dash theres a small button thats easily felt...press it down fully then tug on the shaft and it will come straight out...
Vent cables...the ***** arent removable from the cable...theres a nut on the backside of each...loosen that and pull the cable forward away from the dash for masking if you are painting.
wiper switch...theres a set screw(allen head)...loosen it and the **** slides off the shaft..
The others are straight forward(cig. lighter and glove box door)
- cs65
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
