1951 Marmon Herrington - Ford Truck Enthusiasts Forums
Old 08-12-2012, 07:44 PM
1952henry's Avatar
1952henry 1952henry is online now
1952henry is gaining momentum as a positive member of FTE.1952henry is gaining momentum as a positive member of FTE.
Old 08-12-2012, 08:01 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
Not sure what you are asking. Are you looking for info on this specific truck or on Marmon-Herrington trucks in general?
Old 08-12-2012, 09:30 PM
1952henry's Avatar
No, I have one, and have plenty of info. Just wondering if anyone had seen it before it hit ebay.
Old 08-12-2012, 09:31 PM
kenjh's Avatar
kenjh kenjh is offline
kenjh has a good reputation on FTE.kenjh has a good reputation on FTE.
looks nice ..but only 2 shifters ?? was that normal for the"small" trucks?? and the rear end looks newer ..again ..maybe the little trucks were set up different ..and 3000 miles ..must'a been broke for a long time ..
Old 08-12-2012, 09:34 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
1952henry is a long time Marmon-Herrington owner and knows his stuff on the breed. He's asking about that specific truck. I don't know specifics about it. Stu
Old 08-12-2012, 09:36 PM
Owen - I'll do you a p.m. Stu
Old 08-13-2012, 12:05 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Looks like a clean truck with most of the MH stuff there, right? Wouldn't take much to finish that truck.
Old 08-13-2012, 04:43 AM
1952henry's Avatar
Quote:
The 1/2 (and 3/4 tons up to late 50 or early 51) had single speed transfer cases. They also sported Dana axles as opposed to the Timkens on the 3/4 tons.
Old 08-13-2012, 08:00 AM
This truck is awfully nice, but the missing front stabilizer springs would be a question. Are just the leaves missing and easily replaced, or are the hangers themselves also missing. The pictures don't show that I can tell. These stabilizer springs were used on the LD7-4 half tons and R3-4 single speed 3/4 tons. My '50 and '51 F-3 R3-4s both have them. Stu
Old 11-27-2015, 08:48 PM
464Saloon 464Saloon is offline
464Saloon is starting off with a positive reputation.
Quote:
I have a 51 F 1 mostly original that I would like to restore into a Marmon Harrington . I don't know if any parts are available to do it or I was thinking size wise the early Bronco would get close for starters and go from there. Thoughts or comments?
Old 11-27-2015, 11:33 PM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is online now
bigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud of
I do know that this MH ranger can be bought but not cheap!
Old 11-28-2015, 01:23 AM
I'd suggest getting to know member jpb222 who has done a great 4x4 conversion on his '51 F-1. Here's his thread describing the conversion.
http://www.ford-trucks.com/forums/71...d-f-1-4x4.html
To do a true M-H conversion on your truck you face the task of finding correct donor parts, specifically the front axle, single speed transfer case, and associated mounting hardware. Very rare, very expensive, and you'd be competing with guys like me who are also looking for these pieces to remedy fractured components on original trucks. Stu
1951 FORD 4x4 F6 Marmon-Herrington Dirtbag 1948 - 1956 F1, F100 & Larger F-Series Trucks 137 02-22-2017 11:42 PM
Marmon-Herrington Chris 56 f6 1948 - 1956 F1, F100 & Larger F-Series Trucks 81 10-18-2016 07:37 AM
ebay find jackedupford666 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 02-25-2016 08:02 PM
$122.000 marmon Herrington ranger Chris 56 f6 1948 - 1956 F1, F100 & Larger F-Series Trucks 31 09-19-2015 02:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
