90 5.8l Redline?
If you're having issues revving replace the fuel filter first, replace cap, rotor, wires, and plugs. Verify timing is at 10dbtdc with SPOUT unplugged. If it still does it try dropping the y-pipe off the manifolds and see if it clears up. If so you have a plugged cat if not you have a clutch or transmission problem.
Redline is 5250rpm and that's also where the rev limiter is set.
Thanks guys. I can only assume this motor has 113k on it and I have no intention of revving it past 4k. I just found it odd it did not like to rev to 3k. The clutch has been replaced so next step will be fuel filter and tune up. The fuel filter on it now is a motorcraft so who knows, it could be original to.
RMystique
02-04-2018 11:04 AM
Aaron Hd Frazier
11-28-2012 05:27 PM
93 mix 'n match
13
05-30-2009 04:48 PM
