Fule pumps run too long
My 88 f250 460. When I turn the key on the fuel pumps run for a long time. Maybe a minute or more. The truck will not start until they stop. I am getting fuel out of the tank, before the high pressure pump. That tells me the tank pump is working. I am getting a lot of fuel before the fuel filter. That tells me the high pressure pump is working. I changed the fuel filter. I have a pressure gauge on the rail it is not losing pressure.
I don't know what to do next.
Thank you
Bob F
Thank you
Bob F
X3
Click on this link and do some reading, it's worth a try:A9x ECM's (and same years ECM's) Failures Due to Age
Please let us know if you open the computer up, what you see.
Thanks,
Bob
Thanks,
Bob
Thank you for responding. I did a search, on here, and that pointed to the EEC, so I took one out of one my father-in-laws truck to test. It fixed it right up. My EEc is only a few months old. It is a rebuilt one. I got it from a well known parts store. I doubt I will have any luck geting a warenty. I will still plead my case.
His truck is a 91 f250 460 Auto. Mine is a manual. Will I hurt anything by using his EEC until I get my new one?
on
It won't hurt anything to use that EEC in your truck but it will throw a ton of codes when it finds it's not getting feedback from all the sensors in the auto trans... assuming the '91 has the E4OD trans and not a C6. If that is a C6 truck then you're golden since that's the same as having a manual as far as the EEC is concerned.
AAAAAHAB
16
02-22-2015 12:18 PM
Trapping
04-26-2011 08:04 PM
websthes
09-11-2007 09:39 AM
