F-superduty question - Ford Truck Enthusiasts Forums
Old 08-11-2012, 10:38 PM
94IDIsuperduty 94IDIsuperduty is offline
94IDIsuperduty is starting off with a positive reputation.
I have recently purchased a 1994 f-superduty (f-450 to some) dump truck. It is currently an automatic which i cannot stand. Im looking to convert it to a zf5. My question is will my driveline parking brake from the automatic bolt up to a zf5? Also if im not mistaken they used a 4x4 zf5 in the super duty correct?
Old 08-11-2012, 10:55 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
The F-SUPERDUTY uses a 4x4 trans so yes a ZF-5 4x4 will bolt right up to the brake adapter.
Old 08-12-2012, 01:40 AM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
If youre swapping anyway, and dont mind a little extra work, a zf 6 might be even better.
Old 08-12-2012, 10:20 AM
Thanks for the info guys. Also im not against the zf6 swap but how much more work will it be to install and is it beneficial?
Old 08-12-2012, 10:52 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
what seems to be wrong with the E40D?
Old 08-12-2012, 10:55 AM
No PTO ports and i want a stick lol, other than that the transmission is fine. I would keep it as back up.
Old 08-12-2012, 11:03 AM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
Quote:
The 6spd, has another lower gear to help you get rolling, but it will not be a direct swap,like the ZF5 will be. The drive line park brake from the E4OD will not fit the 6 spd., as the output shaft is larger on the ZF6. It is also taller so you will have to modify the tranny floor cover to get it to fit. Not worth the extra effort in my opinion.
Old 08-12-2012, 11:15 AM
Ya zf6 isnt a bad idea but not really worth it. Plus i dont want to make a custom parking brake. The zf5 has a low enough first anyway.
Old 08-12-2012, 11:25 AM
the E40D is rated to tow more than the ZF5 and is a fairly expensive transmission.it also sports a slightly higher OD gear which will prove helpful for economy with the low gears in the rear axle.at around 35mph,you have a direct connection like a manual anyway.
you can swap in a 1356 t-case with a PTO.
you may just want to run the truck for a while.maybe the auto thing will grow on ya.
swapping out a perfectly fine E40D for a ZF5 would be a downgrade imho.it's one thing if the truck isn't worth the $ for a new/rebuilt E40D when one fails,to just swap in a ZF5 because it can be much cheaper,but id never do such a thing with a good E40D all in working order.
if you ever add a turbo,your boost doesn't drop off between shifts.you keep it.a Zf5 truck can't match the overall performance level of a properly functioning E40D equipped truck.
Old 08-12-2012, 11:26 AM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3 '94IDITurbo7.3 is offline
'94IDITurbo7.3 is gaining momentum as a positive member of FTE.
no real benefit of the ZF6 over the 5.
Old 08-13-2012, 12:47 AM
I appreciate everyone's input and opinions thanks guys.
Old 08-13-2012, 12:50 AM
I forgot the driveline break... oh well. But otherwise, just a tab for the top bellhousing bolts and use the late model 7.3 clutch.
F-superduty ZF 5 question... bbf385 1987 - 1996 F150 & Larger F-Series Trucks 2 03-25-2015 05:37 PM
F-SuperDuty ZF USMC0351fordtruckin 1987 - 1996 F150 & Larger F-Series Trucks 6 08-19-2013 06:58 PM
1989 F-superduty Tranny question old blue beast 1987 - 1996 F150 & Larger F-Series Trucks 3 04-22-2013 05:26 AM
1995 F-450 (F-Superduty) 4x4 Four Paws 1987 - 1996 F150 & Larger F-Series Trucks 1 02-09-2010 10:53 AM
ZF5 2wd or 4wd Naked_Farmer 1987 - 1996 F150 & Larger F-Series Trucks 3 12-21-2008 02:52 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
