4R70W requires heavy throttle to downshift - Ford Truck Enthusiasts Forums
Old 08-11-2012, 09:14 PM
jade79 jade79 is offline
jade79 is gaining momentum as a positive member of FTE.
Hello,
I've been having issues with my 95 F150 (2WD) 4R70W ever since I got it. When I first got it, it would hunt back and forth when it was time to upshift into OD (or converter lock up hard to tell which) I flushed the trans, converter, and cooler and refilled with Mercon 5 fluid. That problem went away.
Now I've noticed it requires heavy throttle opening before it will downshift when climbing a hill. It will slow way down if only gradually depressing the throttle and requires almost 3/4 to full throttle to downshift (unlock t/c). I'm used to my 79 (with a C4) and 63 (with a three on the tree) that only requires the slightest pressure on the throttle to maintain or accelerate up hill. Now I realize they are non OD but I'm thinking the 4R70W should downshift (or unlock) much easier that it currently does.
Thanks.
Has anyone else experienced this issue? Do you think a rebuild would fix this issue or could it be in the ECU/wiring/connectors?
Old 08-11-2012, 09:47 PM
burnout400m burnout400m is offline
burnout400m is starting off with a positive reputation.
The 4r70w is computer controlled so if you scan the codes on the ECM it might give you some insight into what's wrong, if anything.
Old 08-11-2012, 09:53 PM
jk080's Avatar
jk080 jk080 is offline
Gear Head
jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.
This may not even be a transmission problem, this kind of issue is best diagnosed with the use of a scanner that will allow monitoring of the data stream for the transmission and engine. Tps, road speed, engine load, and other factors can effect the way the computer controls the transmission.
Old 08-11-2012, 10:09 PM
Thanks for the replies. I'll be sure and check for codes once I get it back on the road. I'm dealing with brake issues and I found a snapped leaf spring center pin today as well.
I don't think I can communicate with the trans (or even the ABS) with my scanner. This is a 95 so the OBD II data stream wasn't availaible til 96 if I'm not mistaken.
Thanks again.
Old 08-11-2012, 10:33 PM
Well I think the ECM will still show trouble codes for the trans if there are any.
4R70W shuddering? kmeifert 1997 - 2003 F150 69 11-26-2016 09:55 AM
Downshifting. Cruise vs foot meborder Expedition & Navigator 3 04-21-2016 01:01 AM
02 5.4L torque converter kaboom10 1997 - 2003 F150 2 02-26-2015 10:26 PM
Can TS chips change shift points? 1994F2507.3L 1994.5 - 1997 7.3L Power Stroke Diesel 31 09-19-2014 01:24 PM
'01 Expedition, torque converter or other tranny problem? lincolnboy73 Expedition & Navigator 13 08-17-2012 05:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
