No Spark
No Spark
Hey Guys,
Really stumped here. My 1966 f100 352 will not produce any spark. Went ahead and replaced points, rotor, condenser and cap. Also replaced ignition coil and no spark at all. Only thing between coil and ignition is small white rectangular box coming off ignition. Have no clue if this white box is causing my truck to not get spark. Any help would be appreciated.
Rob
Rob
Hey Guys,
Rob
Rob
Yes the rotor is turning when trying to start engine.
I checked for power at the resistor where wire from ignition is connected and got 12.5 volts when ignition is in the on position. I checked for power on side of resistor that was going out to coil and it has same 12.5v reading when ignition is in the on position.
When I moved it to neg. side the truck would not crank. This seems to get worse with each passing minute. Checked batt and put it on charger anyway even though it is at 79%.
I'm really confused why my truck will no longer turn over now.
Test light on pos coil post checked out.
on
If you have been cranking on it a lot the starter may be getting hot. It than will pull a lot more current and the engine won't turn over even with a full battery. Only crank it for a few seconds than let it cool for several minutes or it will smoke the starter motor. The only two things that come to mind as for spark is a bad coil or the ignition wire where it goes into the dizzy is going to ground. Did the test light blink when ya hooked it to the (-) negative side of the coil and cranked the engine? Has it ran since ya put the new points in? Was it running before ya replaced the points or did ya do that to see if that was the problem?
Moved it to the neg. side and stayed light with no flashing. I can't believe the new points are already bad. Could the ignition or resistor be my problem?
Brand new coil.
No, the light stayed on without any blinks.
No
I changed it because it would not start.
Brand new coil.
No
