Vin information Location - Ford Truck Enthusiasts Forums
Old 08-11-2012, 05:40 PM
frmach frmach is offline
frmach is starting off with a positive reputation.
01 F150
When you read the VIN# with a OBD11 scanner where does it get the VIN from, the PCM or the Instrument cluster?
I ask this cause A high dollar Snap On scanner and my little cheapy one
pull difference numbers!
Old 08-11-2012, 06:14 PM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
It comes from the ID block in the program.
Depends on what you call a cheapie scanner.
Most mid ranges scanners can't look at the VIN in a Ford because it's not normally usefull for diagnostics.
One may read it out as a HEX code, another in a different format that still tells the same info when translated. It depends on what, how or why the aftermarket designer chose to write the scanner program and what features he included in the program and hardware to control the PCM data access.
For example, my scanner will cover me up with data from a Chrysler product but not nearly that amount from a Ford.
Does either match what's on the dash board as seen through the windshield on the driver's side and on your title or Lic info or the door jamb tag.?.
If it's of any interest there is a VIN decoder at the top of this page.
Plug in the numbers/letters and see what it tells.
Good luck.
Old 08-11-2012, 07:34 PM
vin location
My little scanner cost about $35.00. His big Snap On cost several thousand. If we pull the PCM neither one reads a VIN. With a new PCM mine does not read any, his will show a # but it is not the VIN on the truck door post.
With the old PCM installed mine reads the correct # from the post but his does not show any! That is why I wonder where the info comes from.
Truck shows a PATS problem.
Old 08-11-2012, 10:38 PM
Has the new PCM been programmed with factory as built data?
Has the keys been reprogrammed along with it?
This must all be done at the same time.
The PATS and the PCM 'marry' each other such that if you make a change both must be addressed with reprogramming.
What are you or have you done?
Old 08-12-2012, 06:21 PM
vin location
Thanks. I think that I understand that but still would like to know where the
number is stored, and if in more than one location.
M100 VIN nicmann 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 12-15-2015 05:51 PM
Trans Temps and OBD Scan Tool (hard wired or BAFX Bluetooth OBD2 scan tool) My-Hobbies 1997-2006 Expedition & Navigator 4 11-02-2015 12:09 AM
vin pineflatg1 1961 - 1963 F100 Unibody 2 05-12-2014 10:02 PM
colour Y Vinford 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-05-2012 12:50 AM
help decode vin xxox 1973 - 1979 F-100 & Larger F-Series Trucks 1 01-07-2012 03:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
