New Guy Old Truck 51 F1
Farm Truck - KansasPlates.org
and a pic of another
http://www.flickr.com/photos/mragan/4874398908/
on
Get the old flatty running as best you can without tearing into it to much. Than make sure ya can stop her as well. Than driver her a while just the way Henry built her. You and her will form a bond and talk to each other in a language only the two of you can understand. Than before long she will tell you what if any upgrades she needs and wants to keep you happy and driving her.
Welcome! 51 sixes are cool....You should be able to make it run...as long as you were able to get the head off. Marvel oil and lots of penetrating oil in the cylinders and around the valves worked for me. Be patient and don't spare the oils, it could take a couple of weeks to break the pistons loose. You may have to take the intake/exhaust manifolds off to get to the lifters...they stick in an old six engine and make it impossible to turn over. Try working the crank back and forth with a big socket on the damper bolt and see if the pistons move. Good luck from a fellow sixer.
Curated Content Editor
06-10-2019 09:19 AM
F-1
12-22-2017 11:31 AM
Chris 56 f6
13
10-04-2015 11:11 PM
Wayne Waldrep
09-21-2012 09:19 PM
Grandpa-50
26
10-10-2011 01:44 AM
